Robzki Posted February 29, 2012 Share Posted February 29, 2012 Which of those pics is your new rad cap? If its the one with the spring then that looks right, the other one with the blue part doesn't look right and wouldn't seat in the neck of the rad and wouldn't let the system pressurise(pressurised water boils at a higher temp iirc) therefore it would just boil into the expansion bottle. The one with the blue part looks like it is broken. which would cause your issues. unless its a strange aftermarket radiator. Link to comment Share on other sites More sharing options...
Fitz Posted February 29, 2012 Author Share Posted February 29, 2012 Shouldn't the cap have 1.1 bar stamped on it, not 0.9? That was my initial thoughts Which of those pics is your new rad cap? If its the one with the spring then that looks right, the other one with the blue part doesn't look right and wouldn't seat in the neck of the rad and wouldn't let the system pressurise(pressurised water boils at a higher temp iirc) therefore it would just boil into the expansion bottle. The one with the blue part looks like it is broken. which would cause your issues. unless its a strange aftermarket radiator. The new rad cap is the one with the spring in it, the old one is a Blitz Rad cap bought from a trader on here almost 2 years ago. I haven't had any problems with overheating with the new rad cap except recently after the car was parked up for 2 months and not used. The new rad cap 'fits' except it wont press down far enough for the teeth to get under the catch. So if anyone knows the part number for a stock rad cap I would be grateful if you could share. Link to comment Share on other sites More sharing options...
Robzki Posted February 29, 2012 Share Posted February 29, 2012 Yeah but the one you have at the moment looks to have failed. The sealing rubber face should be at the same position as the new one. The blue part should be at the bottom, the slits in the metal above the blue bit look like they should be in the groove. Link to comment Share on other sites More sharing options...
Fitz Posted February 29, 2012 Author Share Posted February 29, 2012 Just to check, I've found a part number I believe to be for the stock radiator cap of 16401-62100 can anyone confirm if thats correct? Link to comment Share on other sites More sharing options...
ScottC Posted February 29, 2012 Share Posted February 29, 2012 Just to check, I've found a part number I believe to be for the stock radiator cap of 16401-62100 can anyone confirm if thats correct? Steve Manley will know Link to comment Share on other sites More sharing options...
Supra N_A Posted February 29, 2012 Share Posted February 29, 2012 yea it should have 1.1 bar on the rad cap the 0.9 bar is for smaller cars I think as my glanza have that cap... mine was getting coolant leaking out the expansion tank but i got a new blitz cap and its cured the issue Link to comment Share on other sites More sharing options...
ScottC Posted February 29, 2012 Share Posted February 29, 2012 Just to check, I've found a part number I believe to be for the stock radiator cap of 16401-62100 can anyone confirm if thats correct? Just checked an old invoice and thats the part number I have. Link to comment Share on other sites More sharing options...
Fitz Posted February 29, 2012 Author Share Posted February 29, 2012 Bingo ordered Link to comment Share on other sites More sharing options...
Chris Wilson Posted February 29, 2012 Share Posted February 29, 2012 The system wants checking with a pressure tester first. Then the cap wants pressure testing. If all is OK renew the thermostat and have the rad checked out, if it only overheats in traffic have the fan's viscous coupling checked out. If it's got that hot it may have done damage to the head Link to comment Share on other sites More sharing options...
Robzki Posted February 29, 2012 Share Posted February 29, 2012 Does anyone think that the original cap looks knackered and wouldn't seal therefore just pumping water into the expansion tank...........or is it just me. Link to comment Share on other sites More sharing options...
Fitz Posted March 1, 2012 Author Share Posted March 1, 2012 The system wants checking with a pressure tester first. Then the cap wants pressure testing. If all is OK renew the thermostat and have the rad checked out, if it only overheats in traffic have the fan's viscous coupling checked out. If it's got that hot it may have done damage to the head Can any garage do pressure testing on the coolant system? Link to comment Share on other sites More sharing options...
Pig Posted March 1, 2012 Share Posted March 1, 2012 Fitz, have you checked the basics? So often these things are something simple. I would strongly suggest that you run the car stationary until it get up to temp and start playing about with all the pipes. I am betting that you will find a split in 1. I think the high temps are a red herring. The reason for the high temps is that you are running the car once all the coolant has pissed out. Let us know how you get on. (start with the big hose at the front, the the one right at the back connected the the metal pipe) Need to top the rad up to the top and the expansion tank also. Just use water for the time being. Link to comment Share on other sites More sharing options...
Chris Wilson Posted March 1, 2012 Share Posted March 1, 2012 Can any garage do pressure testing on the coolant system? They certainly shold be able to, yes, it's just like any other car. Link to comment Share on other sites More sharing options...
Fitz Posted March 1, 2012 Author Share Posted March 1, 2012 Fitz, have you checked the basics? So often these things are something simple. I would strongly suggest that you run the car stationary until it get up to temp and start playing about with all the pipes. I am betting that you will find a split in 1. I think the high temps are a red herring. The reason for the high temps is that you are running the car once all the coolant has pissed out. Let us know how you get on. (start with the big hose at the front, the the one right at the back connected the the metal pipe) Need to top the rad up to the top and the expansion tank also. Just use water for the time being. Thanks Pig, I've done the basic checks a few times over to try and establish if there is a leak of some sort. I've been letting the car start from cold and leaving it for about 10-15 mins as it gets to 'normal' operating temperature. I've fiddled with pipes, listened out for hissing noises and looked for leaks, so far nothing. I think I read on an FAQ that the cooling system takes about 9 L of coolant? Is that true? Because if my system went dry after being sat for 2 months I think I'm lacking a few litres. Link to comment Share on other sites More sharing options...
Fitz Posted March 1, 2012 Author Share Posted March 1, 2012 I've also played with the throttle and looked for any sign of a leak, nothing. Link to comment Share on other sites More sharing options...
Chris Wilson Posted March 1, 2012 Share Posted March 1, 2012 So long as the car isn't kept where the temp drops below freezing it's a terrible waste of antifreeze (coolant additive) to be putting it in. Just use ordinary tap water until you find the leak, or problem. It's one of those jobs a good garage should sort in no time, or at lest diagnose. Link to comment Share on other sites More sharing options...
Robzki Posted March 1, 2012 Share Posted March 1, 2012 I would think it could be THE KNACKERED RAD CAP. Link to comment Share on other sites More sharing options...
Fitz Posted March 5, 2012 Author Share Posted March 5, 2012 Well, it's not the rad cap. I put the new one on on Friday morning and now in sat at the side of the road with an overheated engine a few hundred yards away from the garage. Expansion bottle lid has popped off again and is boiling away after letting coolant out on the inside of the bay (Joyful). Passenger footwell is dry although no heat comes through the heaters, just cold air. Link to comment Share on other sites More sharing options...
stevie_b Posted March 5, 2012 Share Posted March 5, 2012 I'd be thinking about the expansion bottle lid popping off. I can't remember if the expansion bottle is pressurised like the rest of the system. Something is pressurising the expansion bottle (which may or may not be normal depending on the previous sentance), but the build-up of pressure is being released by the expansion bottle, not the rad cap. This is strange. I can think of 2 possibilities: 1) the expansion bottle cap is faulty, and releases pressure, thus causing the collant to boil and therefore loss of coolant. 2) the system is over-pressurising. (seems unlikely though: the rad cap should pop, especialyl a new one, when this happens). There might be other things to check that I can't think of. Link to comment Share on other sites More sharing options...
Swampy442 Posted March 5, 2012 Share Posted March 5, 2012 The expansion tank is there to catch coolant once the system pressure overcomes the rad cap spring. I'm thinking water pump now Link to comment Share on other sites More sharing options...
Dnk Posted March 5, 2012 Share Posted March 5, 2012 (edited) The expansion tank has got a simple overflow pipe that comes out the cap and the cap is only a press on job not a screw or rad type fitting, if its got hot pressurised coolant going into it very rapidly it could pop the cap as more is going in than the overflow pipe can cope with If the engine has overheated before then could it have caused a head gasket problem ? Edited March 5, 2012 by Dnk (see edit history) Link to comment Share on other sites More sharing options...
Fitz Posted March 5, 2012 Author Share Posted March 5, 2012 When I checked the dipstick there was no white substance on it and all looked normal and fine. However, the idle has turned lumpy since the last overheat where steam was pouring out of the car. Damaged internals? Link to comment Share on other sites More sharing options...
Fitz Posted March 5, 2012 Author Share Posted March 5, 2012 The expansion tank is there to catch coolant once the system pressure overcomes the rad cap spring. I'm thinking water pump now The water pump has done about 15-20k since it was fitted. I'd hope a brand new OEM water pump would last longer than that. :S It's in with a local garage at the moment having the system pressure tested. Link to comment Share on other sites More sharing options...
Dnk Posted March 5, 2012 Share Posted March 5, 2012 (edited) Worse case senario is head gasket and a warped head, if it is the head gasket i'd have the head checked to see how flat it is and not just slap a new gasket on there. I'd get it into a decent garage to go through some checks on it now and if it is head gasket failing it might pay you to find a replacement engine as they appear to be cheap. If the head is warped then it could very well be scrap due to it going soft and if it needs more than 0.1mm to get the face flat again its in the bin as the cam journals will be out of true by too much. Edited March 5, 2012 by Dnk (see edit history) Link to comment Share on other sites More sharing options...
Fitz Posted March 5, 2012 Author Share Posted March 5, 2012 Just got out of the garage now and they've told me that it's the Head Gasket that's failing. They ran a combustion test and 'it came out yellow straight away'. What are my options now then? Source a new engine as Dnk says? This car is going to be the death of me, either stress related or the Mrs. will kill me Link to comment Share on other sites More sharing options...
