Phormula KS-3 knock analyser
Mike B
Hi All,
Again, Syvecs install has freed my KS-3 from the car.. although the Syvecs did use the knock sensor and cable in the install.
So what I have here is the KS-3 controller and power cable - to fit it you would have to buy the Bosch knock sensor and cable it to the unit which uses a standard mini rca jack plug. Charlie or Ryan know exactly what sensor it is, and probably the cheapest place to find one.
The KS-3 will map your knock as you drive and you can set it to visual and audio alarm if reaches your set limit. They are £235 new, so as it is, £100 delivered?
more info here;
http://www.phormula.co.uk/KnockDetection-KS-3.aspx
