Set of 8 aftermarket injectors
Guest ugp
What have you got? Must be going cheap. Set's of 6 will be considered if I can source another two from somewhere.
Why 8? What engine is it for?
Maybe if you explain what its for people can help. Do you want drop in or side feed for aftermarket rail (assuming 2JZ based)
FWIW, im pretty sure you wont be able to 'rebuild to the correct cc', and certainly not for less than the cost of a used injector. Probably not even the cost of a new one. If you could people wouldnt go to all that hassle with fuel kits and would just rebuild stock 440s.
It's for a 1UZ, hence the 8. I need stock fit injectors, due to top feed rails.
Cheers
Ben
