Mike B Posted February 25, 2012 Share Posted February 25, 2012 Hi All, I have also taken this out of my car as the new ecu seems to have solved any cooling issues I thought I had! It's a complete kit (also includes nozzle) and is programmable. I did not have or feel I needed to use the serial cable, just programmed using the dials.. comes with; - Tank - pump - pressure pipe, front to rear (tank was in boot) - controller - relay - injection nozzle (the larger of the two) you can set minimum pressure cut in (I had it wired to boost pressure via silicon hose) maximum pressure flow point flow rate.. you'll need some wiring to route the cabling how you like it... £150? plus £10 carriage Link to comment Share on other sites More sharing options...
