My hardcore srd bpu++++ build!!!
ADZsupra
once upon a time there was a man who bought a shed...he loved his little shed but was upset and somewhat distraught at the abuse inflicted on the little fellow by the hands of its previous owner..:(
The shed became know as MAX and so the MAX revivial society was founded with the aim to transform the japanese junk boat into a muscled beast from the east...for all that max wanted was be on the open road with the wind blowing beneath his spoiler once again...
This is MAX's story!
PLEASE NOTE: THIS MAY CONTAIN IMAGES THAT SOME VIEWERS MAY FIND DISTURBING!!!!!!!!!!!!![sHOCK][/sHOCK]
Just to sumerise:
Bent Valves
Bent Crankshaft
failed Gaskets
Garden Hose as coolant pipe
3 bolt missing on turbo manifold
scored bores
Oxidisation in the bores!!!!!!!!!!!!
dented and crack exhaust
misalignment
holes in intercooler pipes
front crossmember rotted through
HID ballast wired up wrong
incorrect insulators on injectors..
Plus lots more folks!
Edited by ADZsupra (see edit history)
  • Replies 100
And I was upset to find some light scoring in one of my cylinders......I will never moan about my car again.
I'm under no illusion that Lee can make this into a beautiful car, but at what cost! Surely you would be financially better of buying a nicer condition BPU TT?
You planning on going single?
Id taken a 10k loan out to buy it so cutting my losses and getting another wasnt really an option...was stuck between a rock and a hard place for ages but i just the plunge as they say and it now looks like this...
Head removed and completely overhauled and reworked :)
Block, decked, rehoned, balanced and cleaned up :)
New Crankshaft Balanced and lightened :)
Yes i did inspect the car, it smoked a bit and dint pull as well as my previous j-spec but apparently the valve stem seals needed replacing so i put it down to that..that and being a well known members car i thought i was still on to a good thing! anyway moving on...lol
[ATTACH=CONFIG]146934[/ATTACH]
NEW SRD 264 CAMS FITTED !!:)
[ATTACH=CONFIG]146935[/ATTACH]
Titan Cam Pullys
[ATTACH=CONFIG]146936[/ATTACH]
Injectors cleaned and the correct insulator rings fitted
[ATTACH=CONFIG]146937[/ATTACH]
Cam covers polished
[ATTACH=CONFIG]146938[/ATTACH]
Turbos system fitted, pipes and heat shield polished
[ATTACH=CONFIG]146939[/ATTACH]
probably the most complicated sequential system, courtosy of toyota!! Top marks to Lee for re-assembling it!! all shiney too!
[ATTACH=CONFIG]146940[/ATTACH]
coming together :)
[ATTACH=CONFIG]146941[/ATTACH]
Intake plenum manifold skimmed and polished, lower runner all cleaned, skimmed, new gaskets fittled.
Ok Guys big Finale pics now with full Spec!!
Block Honed balanced, decked and cleaned.
New Pistons, conrods, rings.
ARP Hardware throughout.
New Seals and Gaskets throughout
Head reworked and upgraded.
SRD 264 Cams
Titan Cam Pullys
New Crankshaft, lightened and balanced to SRD spec ;)
New Crank Pully
Whiftbitz Lightened pullys
New Oil Pump
New Water Pump
New Oil Filters
New Fuel Filters
Whifbitz Upgraded Braided Fuel Line. (removes pulsation dampner)
Cleaned and corrected Injectors
TRD Thermostat
Turbo Manifold skimmed
Intake manifold skimmed
SRD Alloys rad
SRD Twin Electric Fans
SRD Cooling Plate
SRD Oil Cooler for Auto Box
New Frnt cross memeber welded in and engine bay cleaned!!!
Blitz intercooler
Blitz Nur spec R (soon be replace by whiftbitz titainum 4")
Apexi SAFC II (going to syvecs soon)
Apexi AVCR (going to syvecs)
plus other goodies!!
Future bits...going to syvecs, with a water/meth injection kit and AEM AFR, possibly mapped in TTC with Race Fuel and a 3200 high stall torque convertor!!
