TheTurtleshead Posted February 24, 2012 Share Posted February 24, 2012 (edited) Hi Guys; Basically the Big case diff I got from Kenblockseal had had the stock rubber differential mounts on the 'ears' of the diff removed. I'm 99% sure you cannot get these replaced from toyota, and nobody makes a polyurethane kit that replaces this bush. Superpro do a poly kit, but it only goes 'around' this bush, it is not a replacement part. I really did not want to go solid bushes, as I would imagine this is horrible on a road car. I approached a company local to me who make custom bushes and mountings for motorsport and the automotive industry at large. They already make 2JZ engine mounts, and the construction of these is simply beautiful! They produced these in a day for me, I will have more blurb from them soon on exactly how much stiffer they are than stock, how they are made and some pictures of them apart from the diff. They should help cut down on axle tramp over stock bushes! I will test them out over the next two weeks, and if they are good they said they will start producing them, any interest in a group buy out there to get it started? Please bear in mind these are only prototypes, and will probably change in design and appearance a bit They said they would work on the rear mounts as well in the future! You can also use your stock castlelated top bush instead of the uprated one, if the ride is too harsh! So you can have two different options of stiffness They are going to produce me a full set of rubber suspension bushes to replace and update the OEM ones. As I am planning on rebuilding a set of subframes for my car. Any interest out there for OEM Quality replacement suspension rubbers? Edited February 25, 2012 by TheTurtleshead (see edit history) Quote Link to comment Share on other sites More sharing options...
Scott Posted February 24, 2012 Share Posted February 24, 2012 Are we talking about all the arms, roll bars etc? If so then I'm definitely interested in the whole lot. Not sure if the diff mounts would be the same though as I have the small diff? Any indication of cost at all? Quote Link to comment Share on other sites More sharing options...
TheTurtleshead Posted February 24, 2012 Author Share Posted February 24, 2012 The Diff mounts cost me £150, but they're a prototype so that's more than they will be I think. Throw in the fact that solid ones are around £260 from titan, and will give much more road noise and vibration, these look like a winner! The rubber on these is very hard, and whilst you can move it with your fingers with a bit of effort, it will be much more solid than stock. Diff mounts are the same mate, big case to small case. Yup, full set of rubber bushes, ARB's, Suspension arms, the lot!. No indication of price on them as I haven't even discussed it with them yet, or managed to get a set of subframes to strip. Quote Link to comment Share on other sites More sharing options...
Kirk Posted February 24, 2012 Share Posted February 24, 2012 Nice idea. Be interesting to see what comes of this. Can they make a duplicate of the OEM spherical bearing on the upper rear arm? Quote Link to comment Share on other sites More sharing options...
sdistc Posted February 24, 2012 Share Posted February 24, 2012 As with all these uprated bush threads, I'm interested - as long as it's a high quality product for a reasonable price. I'm looking for mildly improved on OEM, so this would fit the bill. Quote Link to comment Share on other sites More sharing options...
JamieP Posted February 24, 2012 Share Posted February 24, 2012 The Diff mounts cost me £150, but they're a prototype so that's more than they will be I think. Throw in the fact that solid ones are around £260 from titan, and will give much more road noise and vibration, these look like a winner! The rubber on these is very hard, and whilst you can move it with your fingers with a bit of effort, it will be much more solid than stock. Diff mounts are the same mate, big case to small case. Yup, full set of rubber bushes, ARB's, Suspension arms, the lot!. No indication of price on them as I haven't even discussed it with them yet, or managed to get a set of subframes to strip. Mine has a Titan solid rear end, did you notice any vibration or extra noise from the back when you was in the car? ive certainly never noticed any difference. Quote Link to comment Share on other sites More sharing options...
Littler Posted February 24, 2012 Share Posted February 24, 2012 This is exactly what I'm looking for on the TT. So definitely interested on the full suspension set Quote Link to comment Share on other sites More sharing options...
TheTurtleshead Posted February 25, 2012 Author Share Posted February 25, 2012 Mine has a Titan solid rear end, did you notice any vibration or extra noise from the back when you was in the car? ive certainly never noticed any difference. With a full 4" exhaust system and 1100 HP... Do yo really expect to notice anything when you're in there Jamie? I don't think we can really use your car as a comparison. Quote Link to comment Share on other sites More sharing options...
downimpact Posted February 25, 2012 Share Posted February 25, 2012 This sounds interesting if you're doing a whole set. Quote Link to comment Share on other sites More sharing options...
