p3te Posted February 23, 2012 Share Posted February 23, 2012 I have one of these whifbitz catch tanks and am wanting to fit it to my TT, im fitting it with push on fittings and 19mm silicone hose. On a single turbo it’s just a case of welding a 12AN fitting on your cam cover and fitting a 90 degree fitting but on the TT there’s only about 20mm clearance between the cam cover and the vac hard pipe/turbo pipe there won’t even be enough space for a forged fitting i think, i thought about making a little elbow from some 20mm alloy pipe and could do no bother but then it means i can’t get to the bolt that fixes the cam cover any ideas on how i could fit it? Quote Link to comment Share on other sites More sharing options...
JamieP Posted February 24, 2012 Share Posted February 24, 2012 If you want to go the -12 route and dont have space in the stock position just weld up that hole and put a -12 on the cam cover where you do have room. Quote Link to comment Share on other sites More sharing options...
p3te Posted February 24, 2012 Author Share Posted February 24, 2012 I thought about that but didn't know if it would effect how it, so du reckon it would be fine just welding the hole up and welding a fitting near the back of the cam cover? Quote Link to comment Share on other sites More sharing options...
JamieP Posted February 24, 2012 Share Posted February 24, 2012 Be fine. Quote Link to comment Share on other sites More sharing options...
p3te Posted February 24, 2012 Author Share Posted February 24, 2012 Should make things easier :-) thought it might have needed to be there because of the baffle inside Quote Link to comment Share on other sites More sharing options...
