Foglights don't work
seba
Hi all, i'm having a problem with the orphan i bought about a month ago http://www.mkivsupra.net/vbb/showthread.php?262266-Found-an-orphan-yesterday
I spent 2 days preparing it for it's first mot here in Belgium, after having done everything that has to be done i realized the rear foglight doesn't work. It's a separate foglight put in later on as you all know the supra doesn't come with a rear foglight standard.
It takes its power from the rearlight so should only work when the lights are on and when i push the switch that has been built in on the dash, but nothing happens. After trying different things that didn't work i tried the front foglights (if i am correct the outer lights on the front are foglights not?), and to my surprise they didn't work either. Ofcourse maybe it's just a fuse, i can't check it atm as its pretty dark etc. But the front foglights aren't on the same circuit as the rear foglight so what can cause them to malfunction? I'm a bit lost on the front foglights as i dont know why they wouldn't work. I checked the bulbs they seem to be fine, do the front foglights actually have a fuse on their own? :rolleyes:
Edited by seba (see edit history)
