Nic Posted February 23, 2012 Share Posted February 23, 2012 Ant suggestions how to remove vinyl lettering off the outside of the quarter glass? Quote Link to comment Share on other sites More sharing options...
Gaz6002 Posted February 23, 2012 Share Posted February 23, 2012 Have you tried a hair drier and credit card Nic? Usually softens the glue enough to remove it. Quote Link to comment Share on other sites More sharing options...
SupraP-Z Posted February 23, 2012 Share Posted February 23, 2012 As above, spray with a bit of methylated spirit if its really stubborn, use the heat gun to heat it up and scrape it off (razor blade will work best) just be careful not to damage the window or trim...HTH Quote Link to comment Share on other sites More sharing options...
Dnk Posted February 23, 2012 Share Posted February 23, 2012 Or pour hot water over it if you dont have a hair dryer or heat gun, should be no need to scrape with a razor blade or anything if you warm the glue up enough, also tar and glue remover is best for shifting any glue thats left or carefully use thinners Quote Link to comment Share on other sites More sharing options...
Drew_flux Posted February 23, 2012 Share Posted February 23, 2012 heat and prepsol. then posibly a decal removing wheel in a drill. Quote Link to comment Share on other sites More sharing options...
Stonkin Posted February 23, 2012 Share Posted February 23, 2012 As others have said, heat the stickers up and they should just peel off. Try your best to pull them off in one go to avoid them keep snapping and having to get a fresh edge free again. It will bring most of the glue off with it this way also. All Purpose Cleaner or tar and glue remover to clean up any residue left. Quote Link to comment Share on other sites More sharing options...
Nic Posted February 23, 2012 Author Share Posted February 23, 2012 Cheers guys Quote Link to comment Share on other sites More sharing options...
