seba Posted February 22, 2012 Share Posted February 22, 2012 Hey guys i hope someone can give me some advice, i installed a SARD ecu in my N/A 5sp, the ecu is made for the N/A 5sp. The car starts but after a few seconds it just turns of, putting the original ecu back in and everything works fine. I heard these are plug and play but maybe i'm missing something? Or is it just dead? Quote Link to comment Share on other sites More sharing options...
Dim Sum Posted February 22, 2012 Share Posted February 22, 2012 I'll think there should be another part to the ECU. If i remember correctly you need the other part to work but i can't think what its called right now. Quote Link to comment Share on other sites More sharing options...
seba Posted February 22, 2012 Author Share Posted February 22, 2012 I'll think there should be another part to the ECU. If i remember correctly you need the other part to work but i can't think what its called right now. Engine? Quote Link to comment Share on other sites More sharing options...
RobUK Posted February 22, 2012 Share Posted February 22, 2012 Throttle Control? But I can see that being the issue... Quote Link to comment Share on other sites More sharing options...
Supra Gaz Posted February 22, 2012 Share Posted February 22, 2012 I'll think there should be another part to the ECU. If i remember correctly you need the other part to work but i can't think what its called right now. Fuel? If its like the Mines ecu it is one piece plug and play, maybe it is knackered? Quote Link to comment Share on other sites More sharing options...
Dim Sum Posted February 22, 2012 Share Posted February 22, 2012 Engine? lol .... No not that. But that would help. Quote Link to comment Share on other sites More sharing options...
Jellybean Posted February 22, 2012 Share Posted February 22, 2012 I have one in mine, just plug and play, looks like OEM ecu with sard analyse sticker Quote Link to comment Share on other sites More sharing options...
Dim Sum Posted February 22, 2012 Share Posted February 22, 2012 I have one in mine, just plug and play, looks like OEM ecu with sard analyse sticker Hm..... maybe i'm wrong but i swear i've heard thats as well as the ECU theres another bit to go with it........................ Quote Link to comment Share on other sites More sharing options...
Supra N_A Posted February 22, 2012 Share Posted February 22, 2012 I have one in mine, just plug and play, looks like OEM ecu with sard analyse sticker they are identical thow the oem ecu and the sard ecu but with the aftermarket sticker on lol.. Quote Link to comment Share on other sites More sharing options...
Scott Posted February 22, 2012 Share Posted February 22, 2012 Be sure to make sure you tighten the harness bolt into the casing properly. That can cause issues Quote Link to comment Share on other sites More sharing options...
Jellybean Posted February 22, 2012 Share Posted February 22, 2012 Hm..... maybe i'm wrong but i swear i've heard thats as well as the ECU theres another bit to go with it........................ I never took it out just took off the ecu footwell cover ,maybe something is under the ecu but reading up about it, your send the stock ecu to sard and they fit a ROM with different map tables ,boost cut raised to 1.2 or 1.4 ,speed limit removed and in some instances rev limit raised Quote Link to comment Share on other sites More sharing options...
Jellybean Posted February 22, 2012 Share Posted February 22, 2012 http://www.mkivsupra.net/vbb/showthread.php?192708-Sard-analyse-ECU&highlight=sard+analyse Quote Link to comment Share on other sites More sharing options...
seba Posted February 22, 2012 Author Share Posted February 22, 2012 Ok guys thx will try ! But if it was knackered wouldn't the car start at all? Or has the ecu nothing to do with starter? Quote Link to comment Share on other sites More sharing options...
Guigsy Posted February 23, 2012 Share Posted February 23, 2012 My car has similar symptoms but it's a single with an aem. Starts then after a second cuts off. Garage have checked everything. Only thing left is the ecu... Quote Link to comment Share on other sites More sharing options...
mellonman Posted February 23, 2012 Share Posted February 23, 2012 mine did this with the aem fic but i got round it by putting more fuel in at 0-500 rpm at absolute air preasure. Quote Link to comment Share on other sites More sharing options...
Drew_flux Posted February 23, 2012 Share Posted February 23, 2012 If it turns out to be dead, ill take it. Have a mate that bought one off egay and has a burnt circuit board.Might be able to make one good ecu from two bad ones. Quote Link to comment Share on other sites More sharing options...
