us 95 supra NA-T turbo , need help on saFC wiring , check engine lights right away
Guest mikesloud
Guest mikesloud
hi there ,i have given up as i have looked up several wring diagrams on forums and followed the florida supra install guide on NA-T supra, and im doing a U.S 95 supra auto that is NA to turbo 5 lbs,which is finished , needs some fuel, so i bought a used SAFC and followed digrams for karman, and once hooked up , as soon as you start it ,checkengine light comes on right away and runs rich on wide band ,frequency does not change at all on karman, the same as not hooked up at all, i tried and verified my wiring several times, as i have hooked up several afcs in cars before, and this is my first on a NA supra, so i thought afc was bad, so bought another and same issue, can anyone verify my wires and have diagram or pics some thing has to be wrong, i have setting on karman and pink going to ecu oranger from sensor which is pin is airflow , one i got is cream white with red stripe, can anyone verify it., throttle works rpm works, i do not know why its doing what it is, cant get car tuned until this mess is figured out. please someone with experience give me sone advice been 3 weeks with same problem , i have gone over and over cant figure it out.
