boost/whistling issue, not boost leak
Lude
  • Replies 84
The little dial thingy that rotates is just a small air filter. The smaller VSVs vent built-up pressure to atmosphere when they switch.
right now we might be finally getting there :-)
can i bypass this to see if it is this causing the sound?
or just get a new one and hope?
or is there a way i can test it....
the is a adjusting screw that opens a butterfly valve inside the piping if this is open in anyway it will leak air at the 2nd turbo which could cause your noise,make sure this is set correctly even if it is just to aliminate it from your problem
undo the screw untill there is a tiny gap under it this would then mean that the butterfly valve is fully shut.
right ive looked at the adjusting screw. MAYBE i did play about with this on accident when removing all the pipe work before, im not sure as was few months ago.
anyway here is how mine is set at moment.... there is about 5mm gap....
does this look set wrong?, shall i wind it all the way down to ensure the butterfly flaps inside are closed (not sure if i can set it too low)
doesnt look like i can adjust it while its still on the car so may have to remove it to adjust...
Edited by Lude (see edit history)
the arm is connected to a plate, the plate then touches the screw.
the screw has 5mm of thread showing then touches the metal plate,
as per the pic..
ttc mode and maybe try another boost leak tester at the air filt, so it tests all that side
okay so undo the screw until the arm does not touch the thread of the screw as i said it before , if the screw is too far up it will stop the butterfly from shutting fully and can make noises,
undo the screw so the 5mm you measured is even smaller the gap has to be between the arm and the screw
put car in TTC mode today, car still does the noise.
seemd slightly quieter tho, but not much (not sure if it was in my head, or just because the exuast was louder)
think im going to remove the air filter, and make a boost leak tester from there, and see if any leaks show in that area.
car boosts fine though just this bluddy noise :(
double checked the vacums, all ok there,
i also removed the IACV housing, to check the the reed was closed, and it was.
im going to do a boost leak test again next week, i couldnt do one today as didnt have a compressor.
the noise does come in later/quieter when the car is in TTC though, im 75% sure of that...
again, vacuums all apear fine and correct...
Gasket mate. Seriously, check it. Although it may have looked ok to the eye, it may have warped slightly when it came off, or even a chip in the gasket would kill it. Get a new gasket mate. At least then you have peace of mind that it can then be struck off the list of possibilities.
I've been saying to check the gasket now for over a week on this thread and via pm.
Hopefully he will soon, because the next post that says "i've rechecked the hoses and piping etc", without checking the gasket, I'll be out of trying to help, as obviously isnt listening.
Worst comes to the worst, it rules it out. And as everything else seems to have been ruled out at least once, then the gasket is the next step.
i told him over a month ago, atleast if its not the gasket you can rule it out and they are not expensive
