boost/whistling issue, not boost leak
Lude
  • Replies 84
okay maybe put up a vid of this sound, i did just look at you other thread and you put in a pipe you cut down to size and from the pictures it doesnt look like a clean cut so this might make the noise if you dint clean it up, it is hard for people to help because we are not there to hear it, maybe get on the rollers somwhere so you can hear where its coming from,
but if the car runs fine and boosts as normal live with it turbos do whisle even more so with a induction kit
thanks for input guys. il get a video up soon of it.
i was fitting the turbo 9pm last night just so can take the car to a wedding today :-)
im getting ready to go now so il report back in a day :-)
at least iv got a new hybrid turbo now lol
does it sound like a jet?
my car sounds like a jet and always has since i bought it
i can hear alot of air and carnt find no leaks and im not sure if it should sound like this because i havent seen another turbo supra on the road
Mines the same as well. First turbo doesn't seem all that responsive but it is comparing against the second one. I know the second one is ment to be a kick in the arse but the first just seems to be an added noise
VIDEOS
ive just recorded 3 short videos of the sound. i think some of you may say its normal. but some will say its whistling too loud.
it is whistling too loud for me, and i dont think it should be as loud as it is.....
any ideas?
just to confirm its boosting fine & second turbo comes in fine.
yep iv put an air line in engine twice and put soapy water in various places and not found leak.
and smoke test too with a fag.
the intake manifold bolts and throttl body have been checked, the same gaskets were re used but iv read they are re usable, and boost leak t test wasnt showing signs of leaks there.
would you say its coming from a splut vacuum pipe? or a larger area metal surfce leak?
the intercooler itself maybe?
May sound silly, but have you checked the IC piping itself? Is it possible a silicone hose has split/come loose? Or even a split in one of the pipes itself? If there is no sign of a leak in the bay itself, I'd check the intercooler mate. You could rule that of the list then at least.
when you took off the turbo piping did you touch or adjust the intake air control valve its the one one the long straight pipe near the second turbo, i believe that it might be open alittle and pushing you first turbo boost into the second turbo, just a idea as that does not sound right at all that is not a vac leak way to loud for that, its got to be intake or boosted piping
can you elaborate on this please mate? not sure what you mean....
i did have the pipe off that this was on to clean it up and paint, i dont recall adjusting anything there though? its like an actuator yea? i may have tried to remove it from the pipe, but then just put masking tape round it.
how can i check/correct that?
also if i put the car in TTC mode will that help me trouble shoot anything?
Edited by Lude (see edit history)
It's in a box with a vsv on the side.
this part yea? how would i go about checking or adjusting this then? i didnt really alter anything, just removed the pipe and disconected the actuator from the body of the pipe...
Lude i think mellonman is on about the vsv on the pipework you painted, in the picture above you posted its the vsv on the far left pipe. It looks like a little dial / adjusment thingy. Id be interested in knowing aswell as i took my all my pipework off the other day to paint, and although im yet to get it all back together i was looking at that dial because mine just turns and turns both ways without felling like its doing anything? Can anyone shed some light on this?
Edit: You already know what part im talking about lol
http://i181.photobucket.com/albums/x169/lude200/iacv.jpg
That's it. You don't adjust it, what's inside is a reed valve which stops boost from no1 turbo entering no2 turbo. Ive had it before where my aristo made a honking noise, like a goose, if you revved it at idle. One of the reeds had lifted slightly.
