Fuel filter
coza
Thanks guys another question looking at buying a new fuel pump it's a WALBRO FUEL PUMP - 255LPH
Is that any good ???
As far as i am aware 255lph walbro is the standard for a bpu supra, check the faq's on going bpu and they will tell you which one you need as your requirement will be different depending on if your car is an import or export model. And with regards your fuel filter, please buy a genuine toyota item, as with all your filters genuine parts are far superior and if there was any part I would not buy as a pattern part it would be the fuel filter. Nothing can cause issues just as quick as a dodgy fuel filter, and considering its only an extra £30 its worth it in my opinion. And btw I buy pattern brake discs but two of the things I wont buy from a motor factors are filters and brake pads, so I'm not toooo biased:)
Edited by bigbloodyturbo (see edit history)
