Scott Posted February 20, 2012 Share Posted February 20, 2012 I know some of you guys have access to MrT prices so just wondering if you could check out a few parts for me... Water Temp Gauge Sensor - 90980-11428 Pins for the above - 82998-12440 Coolant Temp Sensor - 90980-11062 Pins for the above - 82998-12620 Also, am I right in saying the "Pins" no. will contain multiple pins if required? Just as they will obviously need to be colour coded and there isn't multiple numbers? Thanks Quote Link to comment Share on other sites More sharing options...
ScottC Posted February 20, 2012 Share Posted February 20, 2012 The pins come individually with a short length of black wire attached. Be prepared to pay over £5 each for them. HTH Quote Link to comment Share on other sites More sharing options...
Scott Posted February 20, 2012 Author Share Posted February 20, 2012 The pins come individually with a short length of black wire attached. Be prepared to pay over £5 each for them. HTH I'm really surprised at that. Is that definitely with regards to the coolant pins? I assumed they would be colour coded with the correct sheath lol. Not really surprised at the cost to be fair Quote Link to comment Share on other sites More sharing options...
ScottC Posted February 20, 2012 Share Posted February 20, 2012 I've just bought 12 82998-12440 for my headlight loom. The packets are labeled as 'Terminal, Repair' which would explain why they are just black. Quote Link to comment Share on other sites More sharing options...
mwilkinson Posted February 20, 2012 Share Posted February 20, 2012 Scott, you have or will have a Syvecs right? Why not get new temp sensors and plugs from EFI parts. Probably cheaper than Toyota. Quote Link to comment Share on other sites More sharing options...
Scott Posted February 20, 2012 Author Share Posted February 20, 2012 Scott, you have or will have a Syvecs right? Why not get new temp sensors and plugs from EFI parts. Probably cheaper than Toyota. That's probably a good shout for the ECU temp sensor actually. I'll still need to get the stocker for the gauge though. Thanks for that, good call Quote Link to comment Share on other sites More sharing options...
Scott Posted February 20, 2012 Author Share Posted February 20, 2012 I've just bought 12 82998-12440 for my headlight loom. The packets are labeled as 'Terminal, Repair' which would explain why they are just black. Ahhahh, thanks for the heads up Quote Link to comment Share on other sites More sharing options...
mwilkinson Posted February 20, 2012 Share Posted February 20, 2012 http://www.efi-parts.co.uk/index.php?categoryID=82 Quote Link to comment Share on other sites More sharing options...
Scott Posted February 20, 2012 Author Share Posted February 20, 2012 http://www.efi-parts.co.uk/index.php?categoryID=82 I don't suppose if you know if it's just 1/8 npt do you? I'm guessing it is but I don't want to go ahead and order it without knowing, I've had it up to the eyeballs with threads lately lol. Quote Link to comment Share on other sites More sharing options...
mwilkinson Posted February 23, 2012 Share Posted February 23, 2012 I don't suppose if you know if it's just 1/8 npt do you? I'm guessing it is but I don't want to go ahead and order it without knowing, I've had it up to the eyeballs with threads lately lol. Sorry Scott only just seen this. No I don't I'm afraid. Did you find out? Quote Link to comment Share on other sites More sharing options...
Scott Posted February 23, 2012 Author Share Posted February 23, 2012 Sorry Scott only just seen this. No I don't I'm afraid. Did you find out? Not even looked at it yet I'm pretty sure it will be but I have a few blanks for the oil sandwich plate so it will be easy enough for me to find out. Cheers Quote Link to comment Share on other sites More sharing options...
