cam covers
redsupratt6spd
yeah don't fancy drilling due to not knowing if all the swarf is out :eek: not sure if the old fitting is pressed into the cover or not. I'll take a pic and post it up and i'll check the inside diameter against the weld on fitting.
If you drill it you need to also drill the baffles out and then refit them after you have drilled and tapped the holes to use bolts, this is so you can clean them properly
