FOSTA Posted February 19, 2012 Share Posted February 19, 2012 Hi dose anybody know if there is an aftermarket throttle body that takes the supra throttle position sensor? Hopfully a 80mm but It could be bigger if it had to be. Sorry if this is a stupid question but it's the first time I've thought about changing for an aftermarket body. Thanks Quote Link to comment Share on other sites More sharing options...
hodge Posted February 19, 2012 Share Posted February 19, 2012 I had a 100mm throttle body on my blue supra. The TPS fitted straight on but it needed some alterations to the wiring. Quote Link to comment Share on other sites More sharing options...
FOSTA Posted February 19, 2012 Author Share Posted February 19, 2012 Yeah I thought as much. What size is the one you got on now? And how did you do the throttle sensor on that? Just I've been looking today and I think my oem body is going to be too big and might not fit :-/ Ive found a 80mm weld on plate incase I need one like. Cheers Quote Link to comment Share on other sites More sharing options...
hodge Posted February 19, 2012 Share Posted February 19, 2012 Yeah I thought as much. What size is the one you got on now? And how did you do the throttle sensor on that? Just I've been looking today and I think my oem body is going to be too big and might not fit :-/ Ive found a 80mm weld on plate incase I need one like. Cheers The 1 I've got at the min is 100mm Veilside throttle body. The Syvecs takes care of any wiring indiscrepencies, so no rewiring was needed. Because your running an EMU the TPS wiring needs rewiring as it doesn't have the facility for ECU pin allocation. Quote Link to comment Share on other sites More sharing options...
FOSTA Posted February 19, 2012 Author Share Posted February 19, 2012 Hmmm I think I'm just going to have to wait and see if the oem one fits with enough room to fit the intercooler piping on. It dosnt look good though as my oem body is 8 inches long :-/ Quote Link to comment Share on other sites More sharing options...
