first or second turbo fail???
Supra N_A
how do you kno if the turbo has failed or is failing?
smoke out of the exhaust system/tint blue smoke?
or does the car still boost OK using 1 turbo or can you really tell one has failed well the 2nd turbo for example on that note?
or mucho different readings on the boost gauge (need one tbh)
**no my turbos are not failing or has failed ;)**
just a general question :sly:
Edited by Supra N_A (see edit history)
A large shotgun sound and a plume of white smoke stretching circa 100 metres was my sign of my hybrid tubbies going bang!
Blue smoke can certainly be a sign of Turbo seals going, not necessarily the turbos themselves. Not sure on Stock but BPU you can certainly tell of a turbo failure the power band disappears off the scale. Boost gauge as you mentioned is the best bet to identify any potential problems - i.e. not running full 1.2 bar but that could be a popped hose or other issue.
I think you just 'know' if it does happen - it's a pretty significant problem.
