manual conversion
tahlil
List is as follows:
Complete gearbox with shifter.
Manual prop
Clutch and brake pedals
Master and slave cylinders
Clutch lines
Flywheel and clutch obviously
Manual transmission tunnel
Shifter seal which bolts to the transmission tunnel
Manual ECU
You will also have to modify your autobox loom.
You can use the Auto ECU no problem :) Adam, I feel like you're my supra pimp lol!
You have to solder 3 wires on the auto box part of the engine loom. You will need a pilot bearing for the back of the flywheel. Also I think the gearbox crossmember is different, make sure you buy a second hand one, they're 330 quidings from toyota! Finally the Manual dash panel inside. :) I think M_life covered the rest!
Edited by TheTurtleshead (see edit history)
