tahlil Posted February 18, 2012 Share Posted February 18, 2012 hey guys, can some one adv what pats are required to complete a manual conversion on a 93 n/a supra? thank you T Link to comment Share on other sites More sharing options...
Littler Posted February 18, 2012 Share Posted February 18, 2012 I'd have a word with m_life or theturtleshead as both of these have done the auto to manual conversion for an NA and will probably be able to help you with the parts needed Link to comment Share on other sites More sharing options...
D8MOA Posted February 18, 2012 Share Posted February 18, 2012 (edited) poor link Edited February 18, 2012 by D8MOA (see edit history) Link to comment Share on other sites More sharing options...
bradleyh_15 Posted February 18, 2012 Share Posted February 18, 2012 Or Keoron he does them! Link to comment Share on other sites More sharing options...
D8MOA Posted February 18, 2012 Share Posted February 18, 2012 obv if your going 5 speed (which i assume you are) parts will be diffrent Link to comment Share on other sites More sharing options...
Kirk Posted February 18, 2012 Share Posted February 18, 2012 List is as follows: Complete gearbox with shifter. Manual prop Clutch and brake pedals Master and slave cylinders Clutch lines Flywheel and clutch obviously Manual transmission tunnel Shifter seal which bolts to the transmission tunnel Manual ECU You will also have to modify your autobox loom. Link to comment Share on other sites More sharing options...
Littler Posted February 18, 2012 Share Posted February 18, 2012 I'd have a word with m_life or theturtleshead as both of these have done the auto to manual conversion for an NA and will probably be able to help you with the parts needed Or Martin (m_life) will spot the thread Link to comment Share on other sites More sharing options...
tahlil Posted February 18, 2012 Author Share Posted February 18, 2012 cheers guys :-) Link to comment Share on other sites More sharing options...
Kirk Posted February 18, 2012 Share Posted February 18, 2012 Or Martin (m_life) will spot the thread Yes indeed... I spotted it from the pub with a pint in my hand! Link to comment Share on other sites More sharing options...
TheTurtleshead Posted February 19, 2012 Share Posted February 19, 2012 (edited) You can use the Auto ECU no problem Adam, I feel like you're my supra pimp lol! You have to solder 3 wires on the auto box part of the engine loom. You will need a pilot bearing for the back of the flywheel. Also I think the gearbox crossmember is different, make sure you buy a second hand one, they're 330 quidings from toyota! Finally the Manual dash panel inside. I think M_life covered the rest! Edited February 19, 2012 by TheTurtleshead (see edit history) Link to comment Share on other sites More sharing options...
Littler Posted February 19, 2012 Share Posted February 19, 2012 Adam, I feel like you're my supra pimp lol! ! Whatever make you say that lol Link to comment Share on other sites More sharing options...
