vacuum caps blitz dsbc r install
ashbuster
hey guys
looking at this guide to fit this
http://www.mkiv.com/techarticles/blitz_dsbc/index.html
it says i need 1/4" vacuum caps
do i really need them that big ? i thought these pipes here where im to block off were smaller?
and where the best place for these in black or purple
also anyone know where i can get this t-piece from to tap into my boost gauge vac line?
heres a photo of it on
or can i use a normal plastic t-piece ? but i think the top part is a different size
also what size silicone hose is best to plumb all of this in?
Edited by ashbuster (see edit history)
hey guys
[ATTACH=CONFIG]146446[/ATTACH]
Its just a normal plastic t-piece and you can buy ones with size to accommodate the hose you requirer. Try Ebay for these plastic t-piece and i'm i believe 5mm Vac lines will do the trick.
Hope this help http://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=p3692.m570.l1313&_nkw=4MM+T+PIECE+VACUUM+HOSE+SILICONE+JOINER+CONNECTOR+PIPE&_sacat=See-All-Categories
What sizer would you recommend for the boost controller fitting 4mm or 6mm ?
some of the vacuum pipe i used was 6mm and some i used 4mm.
(pipe from turbo to boost controller i used the 6mm) then rest the pipe from the intake manifold to boost controller was 4mm.
http://www.ebay.co.uk/itm/Silicone-Vacuum-ASH-Hose-Pipe-Silicon-Water-Air-Coolant-Dump-Valve-Radiator-/290640027512?pt=UK_DIY_Materials_Plumbing_MJ&var=&hash=item8960a3ed56#ht_1168wt_862
nice to order plenty of it as its so cheap, and you bet youl need some again on the car or future car again :)
is there a need to cap these pipes? when i went to fit mine, i found different people had done different things. some had left the pipes on. some capped the pipes. and some left the pipes on but with filters in them. all this got me so confused that i decided that i didnt really need it after all, and just disconnected it lol
thanks guys
does it make any difference what size hose we use as long as it fits?
i have 3mm and 5mm hoses here
diameter doesnt matter no, as long as it fits.
you want to get the pipes as short as possible though (as if they are too long it can spike)
doesnt matter now guys
theres no purple wire coming from the solenoid and there should be
there should be 3 wires (blue/white/purple) which go to the blue/white/purple on the controller and there isnt
So I have given a full refund and apologised just to clear that up, brought the item off two members on here, one for the controller and one the solenoid both were untested by me so sold with a full refund guaranteed if not up to the job for whatever reason
yeah thats right
its not deans fault
dean bought it for his own car but then decided on a ecu instead
full refund was given before i sent it back too
it will be sent back this morning bud
thankyou
im not sure what you can do with it mate but it seems the solenoid is missing a wire (purple)
it could be for a different controller
