add heywood Posted February 18, 2012 Share Posted February 18, 2012 Just need clarification that I have worked this out right. Current wheels are Fronts - 9.5J +40 Rears - 10.5J +36 I need the fronts to be 30mm further out and rears to be 50mm further out. So new wheels would be... Fronts - 10J +15 Rears - 11.5J 0 or 12J +5 Worked out with http://www.1010tires.com/WheelOffsetCalculator.asp cheers for any help Link to comment Share on other sites More sharing options...
JamieP Posted February 18, 2012 Share Posted February 18, 2012 Looks right Add, your current rears look a tight fit though, you might not need to push the new rears out the full 50mm. I would fit the kit and measure how much you need. Link to comment Share on other sites More sharing options...
add heywood Posted February 18, 2012 Author Share Posted February 18, 2012 Looks right Add, your current rears look a tight fit though, you might not need to push the new rears out the full 50mm. I would fit the kit and measure how much you need. Was thinking along the same line mate, just wish Volk did my current wheels at a bigger size Link to comment Share on other sites More sharing options...
add heywood Posted February 18, 2012 Author Share Posted February 18, 2012 Although just seen that Volk they do a 10.5 -5 and -15 that give 41mm and 51 mm wider track respectively, and a 9.5 +10 that give me 29mm on the fronts... hmmmm... Link to comment Share on other sites More sharing options...
