Scott Posted February 18, 2012 Share Posted February 18, 2012 I'm at the point of wiring in my injectors, rather than having the plugs going on over the top I would rather rotate the injectors so that I can plug them in from underneath. Is there any problems with doing so? Obviously I don't want to do it if it's important to have the spray pattern at a certain angle. Cheers Link to comment Share on other sites More sharing options...
Digsy Posted February 18, 2012 Share Posted February 18, 2012 Some injectors dont spray in a plane parallel to the injector axis. Its very common on direct injectors but less so on port injectors. I would have thought you would be OK but its impossible to be 100% sure unless someone with a test rig has checked the spray pattern. Doesn't Chris Wilson have an injector test rig? Link to comment Share on other sites More sharing options...
bigbloodyturbo Posted February 18, 2012 Share Posted February 18, 2012 He does, he's just flowtested my 800's. I'm sure he would be the chap that would know. Link to comment Share on other sites More sharing options...
dude Posted February 18, 2012 Share Posted February 18, 2012 All the injectors we ever run in our flowtester spray in a cone pattern and i ran mine 'rotated' as you put it in the black car. Link to comment Share on other sites More sharing options...
Scott Posted February 18, 2012 Author Share Posted February 18, 2012 Chris flowtested my injectors so I'll make sure that they are in a conical spray pattern and I'm good to go then. Cheers folks Link to comment Share on other sites More sharing options...
