How do i take out the inside fuse box?
Iky
Hi,
Im doing a bit of wiring and want to remove the fusebox under the driver side kick panel. How do I get it free. Is there any fastenings at the top closest to the dashboard?
Ive undone the two 10mm bolts at the bottom and taken off the connectors at the front. Is there some more connectors at the rear? How many?
Thanks in advance. Please put up any photos that may be helpfull :thumbs:
Iky.
Got it loose in the end. There's the little clip between the top relay and blue plug.
http://img97.imageshack.us/img97/2317/img1849y.jpg
I can finally properly wire in my heated seats. For future reference its pin 16 on connector 1H that goes to the heated seat fuse.
The connector is located on the rear of the fuse box, adjacent to the connector for the input ingnition power. (Connector 1J pin5 - thick black/yellow wire)
Edited by Iky (see edit history)
