Neil-NA Posted February 15, 2012 Share Posted February 15, 2012 What adjusters shall i soak with penetrating fluid before going for a geo setup? Pics would help. Quote Link to comment Share on other sites More sharing options...
dan294 Posted February 15, 2012 Share Posted February 15, 2012 Where are you getting the Geo setup done out of interest neil? Quote Link to comment Share on other sites More sharing options...
Dnk Posted February 15, 2012 Share Posted February 15, 2012 All the bolts on the lower arms excluding the ball joints Quote Link to comment Share on other sites More sharing options...
Dnk Posted February 15, 2012 Share Posted February 15, 2012 (edited) These are the 2 eccentric adjusters on the front lower arms, im just looking to see if i have any pics of the rears but the ones i've got dont really show the eccentric adjusters very well. Heres the rear lower arm no 1 eccentric adjuster Sorry i've not got any pics showing the rear lower arm no 2 adjuster or the lower suspension bracket stay for the front Theres good diagrams in the WSM in the suspension & axle section Edited February 15, 2012 by Dnk (see edit history) Quote Link to comment Share on other sites More sharing options...
fastcar Posted February 15, 2012 Share Posted February 15, 2012 On the front bottom wishbones there are 2 bolts that connect the lower wishbone to the subframe. The bolts will have washer attached to them with some marks on them. Lube these on the nut side. And also on the front lower wishbone you will see that there a rod that goes from the wishbone on a angle to the rear part of the front subframe that should have two 14mm bolts. Give these a lube to as they need to undone and can snap of easily. On the rear it is much simpler. There will be two lower control arms with the same bolts with the same looking washer with the marks on them connecting them to the rear subframe. There is only four bolts in all on the rear so a bit easier than the front. Hope this helps you out Quote Link to comment Share on other sites More sharing options...
Neil-NA Posted February 15, 2012 Author Share Posted February 15, 2012 Where are you getting the Geo setup done out of interest neil? There a place in Boltion that i know a few people have used - http://www.nigellangsgarage.co.uk/page/Wheel-Alignment/ These are the 2 eccentric adjusters on the front lower arms, im just looking to see if i have any pics of the rears but the ones i've got dont really show the eccentric adjusters very well. Heres the rear lower arm no 1 eccentric adjuster Sorry i've not got any pics showing the rear lower arm no 2 adjuster or the lower suspension bracket stay for the front Theres good diagrams in the WSM in the suspension & axle section On the front bottom wishbones there are 2 bolts that connect the lower wishbone to the subframe. The bolts will have washer attached to them with some marks on them. Lube these on the nut side. And also on the front lower wishbone you will see that there a rod that goes from the wishbone on a angle to the rear part of the front subframe that should have two 14mm bolts. Give these a lube to as they need to undone and can snap of easily. On the rear it is much simpler. There will be two lower control arms with the same bolts with the same looking washer with the marks on them connecting them to the rear subframe. There is only four bolts in all on the rear so a bit easier than the front. Hope this helps you out Thanks for the help guys Quote Link to comment Share on other sites More sharing options...
Dnk Posted February 15, 2012 Share Posted February 15, 2012 Good luck with getting these undone, i had to cut the offside front arm off on my car as the rear of the 2 adjusters was seized solid and nothing would shift it. Quote Link to comment Share on other sites More sharing options...
Neil-NA Posted February 15, 2012 Author Share Posted February 15, 2012 Good luck with getting these undone, i had to cut the offside front arm off on my car as the rear of the 2 adjusters was seized solid and nothing would shift it. I am hoping they will be all right, the car has only been in the UK 4 years and is relatively low mileage, but we shall see. Quote Link to comment Share on other sites More sharing options...
dan294 Posted February 15, 2012 Share Posted February 15, 2012 There a place in Boltion that i know a few people have used - http://www.nigellangsgarage.co.uk/page/Wheel-Alignment/ Cheers Neil, was going to say, there is a guy in Leyland that I have been speaking to that does Geo setups, keep meaning to get mine in to him as he is only 5 minutes away from me, may be worth a look: http://www.grinspeed.co.uk/services.html Quote Link to comment Share on other sites More sharing options...
Neil-NA Posted February 15, 2012 Author Share Posted February 15, 2012 Cheers Neil, was going to say, there is a guy in Leyland that I have been speaking to that does Geo setups, keep meaning to get mine in to him as he is only 5 minutes away from me, may be worth a look: http://www.grinspeed.co.uk/services.html Thanks mate might have to look inot them as they do corner weighing too Quote Link to comment Share on other sites More sharing options...
dan294 Posted February 15, 2012 Share Posted February 15, 2012 Thanks mate might have to look inot them as they do corner weighing too He seems like a sound guy, does a LOT of WRC stuff. Seems very switched on. His name's Steve. He's off Golden Hill Lane in Leyland, near Berry's timer merchants if you know where they are? Only 5 mins off Junction 28 of the M6. Quote Link to comment Share on other sites More sharing options...
Neil-NA Posted February 15, 2012 Author Share Posted February 15, 2012 He seems like a sound guy, does a LOT of WRC stuff. Seems very switched on. His name's Steve. He's off Golden Hill Lane in Leyland, near Berry's timer merchants if you know where they are? Only 5 mins off Junction 28 of the M6. I'm sure i will find it mate, might go down in the next week, he seems to have worked on some high profile cars and as you say lots of WRC stuff. Quote Link to comment Share on other sites More sharing options...
dan294 Posted February 15, 2012 Share Posted February 15, 2012 The Replica RS 200 he has pictures of on his site belongs to a mate of mines Brother, he did the alignment and geo setup on that. Quote Link to comment Share on other sites More sharing options...
dude Posted February 15, 2012 Share Posted February 15, 2012 The problem is not the nut seizing to the bolt, it is the bolt seizing to the metal tube inside the rubber bush, no amount of lube will remedy this, some lube on the excentric adjuster will make it easier to turn as long as everything else is OK. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted February 15, 2012 Share Posted February 15, 2012 The problem is not the nut seizing to the bolt, it is the bolt seizing to the metal tube inside the rubber bush, no amount of lube will remedy this, some lube on the excentric adjuster will make it easier to turn as long as everything else is OK. Exactly, I have cut many an arm off and them tried to press the cut off part of the bolt out of the bush on a 75 tonne press, and still it won't budge, it just mushrooms. UK cars are the worst of course, as they are often a bit like the Titanic underneath. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted February 15, 2012 Share Posted February 15, 2012 What adjusters shall i soak with penetrating fluid before going for a geo setup? Pics would help. They are like women, lube `em up as much as you like, but they can still be awkward and un-playful whatsits. Quote Link to comment Share on other sites More sharing options...
Dnk Posted February 15, 2012 Share Posted February 15, 2012 As said already its the actual shank of the eccentric adjuster that seizes inside the bush so its very hard to free that off, it wont hurt trying though and will help the nut for sure. If they are seized then they are a bitch and i binned mine and replaced the lot. I think the issue is that they appear to be assembled free of any grease/copper slip from the factory hence the problem. Well mine didn't show any traces on them when i changed them. Quote Link to comment Share on other sites More sharing options...
mellonman Posted February 15, 2012 Share Posted February 15, 2012 i even greased mine after i had replaced them and had a full geo done a couple of months later and they was stiff Quote Link to comment Share on other sites More sharing options...
Neil-NA Posted February 15, 2012 Author Share Posted February 15, 2012 So what your all saying is leave it alone unles you want to spend big bucks. Quote Link to comment Share on other sites More sharing options...
add heywood Posted February 15, 2012 Share Posted February 15, 2012 Let me knw how you get on Neil, mine needs doing when I get the car back from the bodyshop... Quote Link to comment Share on other sites More sharing options...
Neil-NA Posted February 15, 2012 Author Share Posted February 15, 2012 Let me knw how you get on Neil, mine needs doing when I get the car back from the bodyshop... Will do mate although i am starting to doubt if i should get it done as i dont have the money for a big bill at the present. Quote Link to comment Share on other sites More sharing options...
mellonman Posted February 15, 2012 Share Posted February 15, 2012 lub them its not going to hurt but the only way they might get ajustment is if the bush moves in the arm. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted February 15, 2012 Share Posted February 15, 2012 Just loosen one adjuster nut at a time, after Tipex marking the cam positions. see if they will turn, both ways, through the full adjustment range. If they will, set them back to the marks and go for a geometry reset confident they are free. If not expect very big bills. Quote Link to comment Share on other sites More sharing options...
Neil-NA Posted February 15, 2012 Author Share Posted February 15, 2012 Just loosen one adjuster nut at a time, after Tipex marking the cam positions. see if they will turn, both ways, through the full adjustment range. If they will, set them back to the marks and go for a geometry reset confident they are free. If not expect very big bills. Ahh good idea thank you Sir Chris Wilson. Quote Link to comment Share on other sites More sharing options...
wile e coyote Posted March 1, 2012 Share Posted March 1, 2012 how did you grt on ? mine went in today but they had problems due to seizing. im going to do as chris said and keep them sprayed with penetrating fluid for a few weeks and ill keep trying to move then get them to have another go. Its not far out luckly Quote Link to comment Share on other sites More sharing options...
