Dim Sum Posted February 14, 2012 Share Posted February 14, 2012 What size hose to join from standard throttle body to intercooler pipe? Quote Link to comment Share on other sites More sharing options...
FOSTA Posted February 14, 2012 Share Posted February 14, 2012 It depends what size intercooler piping you have mate! I'm guessing the throttle body is 76mm (3inch) Quote Link to comment Share on other sites More sharing options...
Dim Sum Posted February 14, 2012 Author Share Posted February 14, 2012 So its safe to say its best to buy a size bigger than getting a tight fit? Quote Link to comment Share on other sites More sharing options...
FOSTA Posted February 14, 2012 Share Posted February 14, 2012 (edited) No you don't want any leaks! If your throttle body is 76mm across then get a 76mm joiner and it will go stright on with ease and will be nice and snug mate! My throttle body is 76mm and my intercooler piping is 63mm so I bought a 76mm to 63mm silicone reducer and it fits perfect! But mine is an NA-T and im not sure if your throttle body is 76mm but I would of thought it would be With piping it when it says 76mm it will be external diamator With silicone when it says 76mm it will be the internal diamator So it fits perfect. Edited February 14, 2012 by FOSTA (see edit history) Quote Link to comment Share on other sites More sharing options...
Dim Sum Posted February 14, 2012 Author Share Posted February 14, 2012 76mm internal is what I've been referring too. So okay i go with 76mm thanks for your advice I should of paid more attention on the hose sizes when I first brought it. Quote Link to comment Share on other sites More sharing options...
Scott Posted February 14, 2012 Share Posted February 14, 2012 Mine isn't a straight joiner. IIRC the intake manifold is a weird size. I know that I definitely needed a downsizing joiner but I can't remember the sizes. Quote Link to comment Share on other sites More sharing options...
FOSTA Posted February 14, 2012 Share Posted February 14, 2012 Pmsl I'm pretty sure it will be 76mm But it only takes a second to run a tape measure across to double check it Quote Link to comment Share on other sites More sharing options...
Dim Sum Posted February 14, 2012 Author Share Posted February 14, 2012 (edited) ordered a straight from Demon tweeks already ......... If it turns out to be wrong i guess i could keep it for spares, but i had a quick look didn't take a measurement but it looks like ive been using a straight joiner Edited February 14, 2012 by Dim Sum (see edit history) Quote Link to comment Share on other sites More sharing options...
Scott Posted February 14, 2012 Share Posted February 14, 2012 ordered a straight from Demon tweeks already ......... If it turns out to be wrong i guess i could keep it for spares, but i had a quick look didn't take a measurement but it looks like ive been using a straight joiner So you measured the coupler you have rather than the TB and the intercooler pipe? Does that not seem a bit daft? lol. Quote Link to comment Share on other sites More sharing options...
Dim Sum Posted February 14, 2012 Author Share Posted February 14, 2012 So you measured the coupler you have rather than the TB and the intercooler pipe? Does that not seem a bit daft? lol. To be honest i didn't measure any thing, did a post maybe look around the Internet, waited for some answers and im straight on ordering it .... all i did was go outside to see if it is a straight joiner or not. Quote Link to comment Share on other sites More sharing options...
Scott Posted February 14, 2012 Share Posted February 14, 2012 To be honest i didn't measure any thing, did a post maybe look around the Internet, waited for some answers and im straight on ordering it .... all i did was go outside to see if it is a straight joiner or not. Man you're lazy. Quote Link to comment Share on other sites More sharing options...
Dim Sum Posted February 14, 2012 Author Share Posted February 14, 2012 Man you're lazy. I was waiting for that lol. I had a rough idea what size but i just wanted a bit of reassurance, if it is too small or big im sure one day it come in handy. If i did measure it, i would of still posted just to double check. Quote Link to comment Share on other sites More sharing options...
Scott Posted February 14, 2012 Share Posted February 14, 2012 I was waiting for that lol. I had a rough idea what size but i just wanted a bit of reassurance, if it is too small or big im sure one day it come in handy. If i did measure it, i would of still posted just to double check. Posting to double check wouldn't make any difference as different hardpipes are different diameters so there is no sure answer. The only thing people would be able to tell you for certain would be the outer diameter of the throttle body, the size of your hardpipe would need to be measured to see if you needed a downsizer. Quote Link to comment Share on other sites More sharing options...
Dim Sum Posted February 14, 2012 Author Share Posted February 14, 2012 Posting to double check wouldn't make any difference as different hardpipes are different diameters so there is no sure answer. The only thing people would be able to tell you for certain would be the outer diameter of the throttle body, the size of your hardpipe would need to be measured to see if you needed a downsizer. Thanks for both of your advice, really appreciate it. I did mention i had a look, on my car its using a straight joiner and seems to be fine. But for future reference i will take note. Most bits were fitted by Keron so its my first attempt at these stuff, just trying to gain more understanding so i carry some basic things. Quote Link to comment Share on other sites More sharing options...
Scott Posted February 14, 2012 Share Posted February 14, 2012 You going for a colour change? Quote Link to comment Share on other sites More sharing options...
Dim Sum Posted February 14, 2012 Author Share Posted February 14, 2012 You going for a colour change? Yes i am. Quote Link to comment Share on other sites More sharing options...
