Rear Subframe part numbers
Lee Burley
Hi Folks, I need a new rear subframe for my 93TT Auto Aerotop. Looking on the EPC all the models seem to have the same part number - can someone confirm this before I waste money on the wrong thing? The scappies are tending to have non turbo autos for example. Thanks!
Yes, they are all the same, with the only slight difference being the NA subframe only has one rear diff mount / Bush. The hole is there for it, so if you do buy an NA sub frame you can buy a new mount / bush from Toyota and smack it in. Hope this helps.
