Guest Rsand85 Posted February 13, 2012 Share Posted February 13, 2012 ok shifted this here to see if i could get some more interest ok after a bit of help here this is something i can never get my head around!!and i know there's a few on here that's good at it!Trying to work out a final drive for my buggy so i can order sprockets with correct tooth numbers. The standard R1 engine runs a 16/43 sprocket set up and will do 180mph at max rpm of 11700 with a tyre diameter of 640mm. To high top end for off road im after quick acceleration not so much top end!!!. Im running 12" rear rims with kenda executioners 673mm diameter tyres and need to gear it for around 130mph max at 11700rpm. I will be running a 14T drive sprocket need to work out what size rear sprocket i need?? Quote Link to comment Share on other sites More sharing options...
