Jap rear pads
wesmi01
OK.
If you don't have the original wheels, then we need to find out what kind of brakes your car has.
If it had 16" wheels when it left the factory then it would have had the "small" brakes (sliding calipers). If it had 17"s then it could have had either "big" (UK spec - fixed calipers) or "small" brakes, because at some point 17" wheels and UK brakes became an option on JDM cars.
Simplest way to tell is to look at the calipers and either post a pic here or try to see if it has sliding calipers or not. Visually the big and small brakes are very different, but I'm at a bit of a loss how to describe it on here.
At a guess from the model year I would say that you have the small brakes, unless someone has done an upgrade since.
