drift_bear Posted February 12, 2012 Share Posted February 12, 2012 Just asked him and he said he drives a 200sx 1.8 turbo with about 400hp If he's running an S13 with 400bhp then its had a serious amount of money into it! is he on sxoc? I wouldn't mind seeing if he has a build thread Link to comment Share on other sites More sharing options...
tDR Posted February 12, 2012 Share Posted February 12, 2012 1.8 turbo 400hp?? What spec is this engine Gonna need a built engine for that in an S13 - the CA18DET is notorious for having chocolate big ends, even stock they seem to let go if you check the tach works all the way round :O A stock S13 with the CA18DET 1.8 Turbo has around 180bhp, with the standard T25 Turbo you won't see over ~230bhp with BPU plus a chip, the easy swap is the T28 Turbo from the S14 but that needs a FMIC and a stage 2 chip to see ~270bhp if the big ends bearings haven't already introduced the crank to the rods. 400bhp is major engine surgery plus much bigger (and laggier!) Turbo as well as all the other expensive fuelling and ECU mods. The advantage they have is weight as they come in around 1200KG vs the JZA80 at around 1500KG but even so the power delivery is pretty shit when they're modded and the chassis struggles to get the power to the ground. 200SX's are just plain hassle when modded and I do speak from experience - most spend ~90% of their time off the road and ultimately rot themselves into a grave as well. To get a real world perspective, look at quarter mile times - 200SX's struggle to get into the 13's where a BPU Supra can do an 11.5 As for standard or BPU.... JZA80 Supra TT's are creamy smooth when standard, very very fast but the delivery is almost dull it's so smooth, you just gather a lot of speed with minimal fuss. Going BPU is like upsetting a reformed serial killer - the rage comes flooding out and the power delivery takes on an altogether vicious edge. It'd be rude not to IMO but then I like to feel like the car I'm driving has the potential to kill me should I drive it wrong. Cheers, Brian. Link to comment Share on other sites More sharing options...
ashbuster Posted February 12, 2012 Share Posted February 12, 2012 (edited) he could also be lying he did say supras was slow lol Edited February 12, 2012 by ashbuster (see edit history) Link to comment Share on other sites More sharing options...
Supra N_A Posted February 12, 2012 Share Posted February 12, 2012 stock TT supra is rapid!! can not WAIT to bpu the beasty!! Link to comment Share on other sites More sharing options...
tony tt Posted February 12, 2012 Share Posted February 12, 2012 Gonna need a built engine for that in an S13 - the CA18DET is notorious for having chocolate big ends, even stock they seem to let go if you check the tach works all the way round :O A stock S13 with the CA18DET 1.8 Turbo has around 180bhp, with the standard T25 Turbo you won't see over ~230bhp with BPU plus a chip, the easy swap is the T28 Turbo from the S14 but that needs a FMIC and a stage 2 chip to see ~270bhp if the big ends bearings haven't already introduced the crank to the rods. 400bhp is major engine surgery plus much bigger (and laggier!) Turbo as well as all the other expensive fuelling and ECU mods. The advantage they have is weight as they come in around 1200KG vs the JZA80 at around 1500KG but even so the power delivery is pretty shit when they're modded and the chassis struggles to get the power to the ground. 200SX's are just plain hassle when modded and I do speak from experience - most spend ~90% of their time off the road and ultimately rot themselves into a grave as well. To get a real world perspective, look at quarter mile times - 200SX's struggle to get into the 13's where a BPU Supra can do an 11.5 As for standard or BPU.... JZA80 Supra TT's are creamy smooth when standard, very very fast but the delivery is almost dull it's so smooth, you just gather a lot of speed with minimal fuss. Going BPU is like upsetting a reformed serial killer - the rage comes flooding out and the power delivery takes on an altogether vicious edge. It'd be rude not to IMO but then I like to feel like the car I'm driving has the potential to kill me should I drive it wrong. Cheers, Brian. Cheers for the info on that Brian. It would be interesting to know if the guy with the 200sx was for real or just trying to put him off a supra because he knows it's quicker than his. Link to comment Share on other sites More sharing options...
Lude Posted February 12, 2012 Share Posted February 12, 2012 i loved my S13, was only about 200-220BHP, but had 15PSI and loud as hell, i even have dreams about it Link to comment Share on other sites More sharing options...
tbourner Posted February 12, 2012 Share Posted February 12, 2012 I was looking into getting a 200sx.......... for the missus to learn in. Link to comment Share on other sites More sharing options...
Nic Posted February 12, 2012 Share Posted February 12, 2012 Another thing to consider, running higher than stock boost will reduce the life of the turbos. J-spec turbos can blow the ceramic turbines, UK spec turbos tend to wear seals/bearings quicker. Removing the cats and upping the boost really does bring a TT to life, but it can get very expensive if you need to replace the turbos. Link to comment Share on other sites More sharing options...
ashbuster Posted February 12, 2012 Share Posted February 12, 2012 can uk spec turbos go straight onto a jap spec if you transfer the setup over? Link to comment Share on other sites More sharing options...
Dnk Posted February 12, 2012 Share Posted February 12, 2012 (edited) I think maybe he hadn't been in one and was just saying what he had heard about them. Doesn't it cost about £1000 to do all the BPU upgrades ? I guess if I could get a standard one cheap in good condition and then go BPU it would still not be too expensive. I've been in one other car with about the same power(audi s4)and it felt kind of quick but I would get bored quite quickly but I think thats because it was a paddle shift and supercharged. It just had a very boring power delivery I think. Be very carefull what you buy, cheap and good rarely go together, there are some nice tt's around and some sheds. What are you thinking your budget will be to buy the car ? Try calling LWIB for a quote and if you can do a limited mileage policy it should keep your premium down quite a bit. My cars bpu and around 400 ish hp so if you want a run out in it after the gritters have stopped give me a shout. Edited February 12, 2012 by Dnk (see edit history) Link to comment Share on other sites More sharing options...
ashbuster Posted February 12, 2012 Share Posted February 12, 2012 Be very carefull what you buy, cheap and good rarely go together, there are some nice tt's around and some sheds. What are you thinking your budget will be to buy the car ? Try calling LWIB for a quote and if you can do a limited mileage policy it should keep your premium down quite a bit. less of the sheds dunk you mean not so nice ones Link to comment Share on other sites More sharing options...
thedirtycat Posted February 12, 2012 Author Share Posted February 12, 2012 Cheers for the info on that Brian. It would be interesting to know if the guy with the 200sx was for real or just trying to put him off a supra because he knows it's quicker than his. Its a built CA18DET forged everything, with tomei camshafts etc etc custom map 550cc injectors Z32 MAF Walbro fuel pump GReddy spark plugs got the RPS Max street pro clutch kit 1.2mm cometic metal headgasket Thats what he said it has. I don't think he is worried about me having a faster car because he lived in another country haha Link to comment Share on other sites More sharing options...
Dnk Posted February 12, 2012 Share Posted February 12, 2012 No i mean sheds, i've seen plenty now that i wouldn't touch with a very long stick. Quite a few of these have actually looked okay untill you start looking a bit closer at the underneath, brakes on their last legs, radiators on the verge of failing, smic's falling apart, heater matrix by passed because its leaking, etc etc I would not buy a 17 ish year old one unless i could have it on a ramp, if its cheap then it probably wont be by the time youve fixed it Link to comment Share on other sites More sharing options...
thedirtycat Posted February 12, 2012 Author Share Posted February 12, 2012 Be very carefull what you buy, cheap and good rarely go together, there are some nice tt's around and some sheds. What are you thinking your budget will be to buy the car ? Try calling LWIB for a quote and if you can do a limited mileage policy it should keep your premium down quite a bit. My cars bpu and around 400 ish hp so if you want a run out in it after the gritters have stopped give me a shout. I was thinking about £8000 for a tt6 and it looks like they don't go any cheaper. I don't really want to get something thats in bad condition though. Link to comment Share on other sites More sharing options...
Rob W Posted February 12, 2012 Share Posted February 12, 2012 I was looking into getting a 200sx.......... for the missus to learn in. Link to comment Share on other sites More sharing options...
tooquicktostop Posted February 12, 2012 Share Posted February 12, 2012 A cheap TT6 can be found, however if you are looking for a strong BPU car you are going to need to spend a few grand to get it all up to scratch for the extra power, I have brought a TT6 for £3750 in the past and I drove that for almost a year with no issues at stock power, I have just purchased a £4K TT6 and will need to spend 6K to get a mint BPU+ car, you can get silly with the spending on a Supra once you start Link to comment Share on other sites More sharing options...
thedirtycat Posted February 12, 2012 Author Share Posted February 12, 2012 A cheap TT6 can be found, however if you are looking for a strong BPU car you are going to need to spend a few grand to get it all up to scratch for the extra power, I have brought a TT6 for £3750 in the past and I drove that for almost a year with no issues at stock power, I have just purchased a £4K TT6 and will need to spend 6K to get a mint BPU+ car, you can get silly with the spending on a Supra once you start Where the hell are you finding them at those prices ? The cheapest I have seen them go for is about £7000 or just under. Link to comment Share on other sites More sharing options...
tooquicktostop Posted February 12, 2012 Share Posted February 12, 2012 Widen your search, be prepared to wait and haggle Link to comment Share on other sites More sharing options...
dude Posted February 12, 2012 Share Posted February 12, 2012 I bought a TT6 for under 4K a while ago. Link to comment Share on other sites More sharing options...
CJ Posted February 12, 2012 Share Posted February 12, 2012 Widen your search, be prepared to wait and haggle Good advice. There are good cars out there at good vfm providing you are patient. Buy in haste and repent skint! Link to comment Share on other sites More sharing options...
RobD Posted February 12, 2012 Share Posted February 12, 2012 Its a built CA18DET forged everything, with tomei camshafts etc etc custom map 550cc injectors Z32 MAF Walbro fuel pump GReddy spark plugs got the RPS Max street pro clutch kit 1.2mm cometic metal headgasket Thats what he said it has. I don't think he is worried about me having a faster car because he lived in another country haha Just 550cc's for 400bhp? I'm aiming for 400bhp from my s14a and ive been told 740-850cc's minimum for that power! :S Link to comment Share on other sites More sharing options...
dude Posted February 12, 2012 Share Posted February 12, 2012 Just 550cc's for 400bhp? I'm aiming for 400bhp from my s14a and ive been told 740-850cc's minimum for that power! :S Thats 4 cyl for you !!!! 90% of the 400 hp J spec BPU's are on 440's Link to comment Share on other sites More sharing options...
johnny g Posted February 12, 2012 Share Posted February 12, 2012 The Supra is 6 cylinder, not 4 - might explain it! Link to comment Share on other sites More sharing options...
dude Posted February 12, 2012 Share Posted February 12, 2012 The Supra is 6 cylinder, not 4 - might explain it! Too late Link to comment Share on other sites More sharing options...
johnny g Posted February 12, 2012 Share Posted February 12, 2012 Too late I applaud your efforts. Link to comment Share on other sites More sharing options...
