Guest kinkydeviltom Posted February 12, 2012 Share Posted February 12, 2012 This is 1 of those silly questions i just wanted to clear up, do suspensions have a left and a right side or are they the same and can fit on either side, ? Link to comment Share on other sites More sharing options...
ashbuster Posted February 12, 2012 Share Posted February 12, 2012 (edited) this is in the wrong place bud might be better to put it in supra chat or mkiv technical this is in car entertainment edit its been moved Edited February 12, 2012 by ashbuster (see edit history) Link to comment Share on other sites More sharing options...
Iky Posted February 12, 2012 Share Posted February 12, 2012 The actual shock bodies are NOT handed so are exactly the same both sides. But I do not know about the topmount bushings. Link to comment Share on other sites More sharing options...
JamieP Posted February 12, 2012 Share Posted February 12, 2012 Some are marked for left and right, others not, my Teins go any side. Link to comment Share on other sites More sharing options...
ripped_fear Posted February 12, 2012 Share Posted February 12, 2012 Some are marked for left and right, others not, my Teins go any side. sorry to go off topic, but would this be the same for tein springs as i have a set waiting to go on my car. Also would you know if the front springs would be different to the rear? Link to comment Share on other sites More sharing options...
Iky Posted February 12, 2012 Share Posted February 12, 2012 sorry to go off topic, but would this be the same for tein springs as i have a set waiting to go on my car. Also would you know if the front springs would be different to the rear? If the spring rates are different then yes. Link to comment Share on other sites More sharing options...
Westy Posted February 12, 2012 Share Posted February 12, 2012 (edited) Spring rate will more than likely be higher on the front to accommodate the engine weight. Lower on the rear for better traction! Edited February 12, 2012 by Westy (see edit history) Link to comment Share on other sites More sharing options...
ripped_fear Posted February 13, 2012 Share Posted February 13, 2012 cheers guys. Link to comment Share on other sites More sharing options...
Chris Wilson Posted February 14, 2012 Share Posted February 14, 2012 Do you mean dampers, springs or wishbones and link arms? We need to know! Link to comment Share on other sites More sharing options...
ADD Posted February 14, 2012 Share Posted February 14, 2012 My meister r suspension goes any side too Link to comment Share on other sites More sharing options...
Guest kinkydeviltom Posted February 14, 2012 Share Posted February 14, 2012 Just the whole suspension when you unbolt the large nut and bolt at the bottom and the 3 nuts inside the boot! Link to comment Share on other sites More sharing options...
