Blitz SBC i-Color Boost Controller In Silver
a98pmalcolm
Hi all. Ok this is a real nice bit of kit I have for sale. Its a Blitz SBC i-Color Boost Controller In Silver but its more than just an average boost controller. The unit In perfect working order.
Few details about the item:
Blitz SBC i-Color Boost Controller(silver) is the latest in the range of Blitz Boost Controllers and represents a revolution in both performance and display. Featuring a 65,000 colour display, and a screen that can be flipped so that it can be mounted in different positions. The SBC i-Color's primary purpose is electronic boost control and the Spec S version, employs a single solenoid design for for sharp boost response and can control boost pressure. The head unit can also display a multitude of readings including boost, power and torque, speed and rpm. With the relevant sensors fitted the unit can also display oil/water temperature, oil/fuel pressure The SBC i-Color can also read wideband air/fuel ratio with the addition of the A/F Analyser. Note: There are 2 plugs for optional sensors. One is strictly for Temperature and the other is for either Pressure OR A/F Analyser. The unit is not able to display both Pressure and A/F. All this funtionctionality means that many gauges can be combined into one unit, especially useful for those with limited dashboard space. Optional Temperature Sensor - part no 19210 Optional Pressure Sensor - part no 19211 Optional A/F Analyser - part no 15063
These retail at around £570. I will also be supplying a full coloured instruction English manual that I printed off the net.
Very good price at £300 + Delivery!
Pics
http://img59.imageshack.us/img59/9513/20120211162557.jpg
http://img36.imageshack.us/img36/9540/20120211163004.jpg
http://img830.imageshack.us/img830/9897/15081.jpg
Thanks
Paul
Ok this is the last thing I have up for grabs. I have some people interested in it. Most probably the best boost controller on the market!
If you use 1.3bar or less you can use the solenoid that's supplied..
Send a payment tonight and I can send tomorrow as I do I post Tuesdays..
Would you just need to change the solenoid if running higher boost?
Yer you need the spec R solenoid. There about £250 from blitz.. IF you want this boost controller new with the spec R solenoid there around £750! madness! So its a big saving getting a second hand boost controller and buying the spec R solenoid separate. But you may be able to sell on the Spec S solenoid that I will be supplying. There around £80 new.
As you will need to buy the spec R solenoid I will do the boost controller slightly cheaper at £340 for you mate. Let me know...
EDIT: Shane it comes in 2 versions The one that retails close to £600 is the one im selling with the spec S solenoid. The as above the ones that come with the twin spec R solenoid are around £750! But this boost controller really does alot! The rolling graph readouts are pretty impressive that are displayed on the unit...
