Mario Posted February 11, 2012 Share Posted February 11, 2012 Up to 1.5 bar actually Amazing, !! That should be fast. Link to comment Share on other sites More sharing options...
Abz Posted February 11, 2012 Share Posted February 11, 2012 Great result!! Any video's of the dyno run? Never really ventured into cams, would be interested to hear how they sound on idle & WOT. Link to comment Share on other sites More sharing options...
RB-GTE Posted February 11, 2012 Share Posted February 11, 2012 Just wondering why TTC was terrible on the stock ECU ? I'd like to do TTC on the stock ECU? If I had to start dumping extra money on ECU and some other stuff, I'd rather hold off and just get a smaller single personally. Link to comment Share on other sites More sharing options...
Littler Posted February 11, 2012 Share Posted February 11, 2012 Just wondering why TTC was terrible on the stock ECU ? I'd like to do TTC on the stock ECU? If I had to start dumping extra money on ECU and some other stuff, I'd rather hold off and just get a smaller single personally. I believe it's due to over fueling Link to comment Share on other sites More sharing options...
RB-GTE Posted February 11, 2012 Share Posted February 11, 2012 What's the cost on the Syvecs ? cheers Link to comment Share on other sites More sharing options...
Scott Posted February 11, 2012 Share Posted February 11, 2012 What's the cost on the Syvecs ? cheers 2k+ Link to comment Share on other sites More sharing options...
Littler Posted February 12, 2012 Share Posted February 12, 2012 2k+ But it's 2k well spent Link to comment Share on other sites More sharing options...
Samurai 20V Posted February 12, 2012 Share Posted February 12, 2012 Thats impressive figues.. Why was the car mapped with TTC mode and not in sequential mode? Link to comment Share on other sites More sharing options...
a98pmalcolm Posted February 12, 2012 Author Share Posted February 12, 2012 Yer with the traction control, knock sensor and mapping was about £2250, and yep its well spend as its all prep for the big single Hi Samurai. Ryan suggested TTC as it works great with the Syvecs unit. I did hesitate as it was god awful on the stock ECU. TTC on Syvecs makes it a much more predictable car. You don't get constant surge of power when its not needed. The turbos kick in around 2-3000 RPM so not much lag at all. But with Syvecs you get launch control so theres no real problem with lag. On the plus side with the 1st turbo being off on low revs it saves a little bit of fuel. And the exhaust is a little more growling with the wastegates open on the low end Link to comment Share on other sites More sharing options...
jjs_82 Posted February 12, 2012 Share Posted February 12, 2012 Is that the plug and play or did you get it wired in. Link to comment Share on other sites More sharing options...
Ryan.G Posted February 12, 2012 Share Posted February 12, 2012 Its Plug and Play But some wiring for Traction control is needed to be done from ABS ecu. Instructions comes with it though Ryan Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted February 12, 2012 Share Posted February 12, 2012 top work mate Link to comment Share on other sites More sharing options...
Ryan.G Posted February 12, 2012 Share Posted February 12, 2012 top work mate You think thats good!, You wait to you see what i have for you. Been Testing the Traction control and its sounds insane!! All gearshift issues now sorted and were making up kits as we speak! Link to comment Share on other sites More sharing options...
Graham1984 Posted February 12, 2012 Share Posted February 12, 2012 Great results and the usual top notch work done yet again..... Time to sit in my NA and have a cry. Link to comment Share on other sites More sharing options...
Gaz6002 Posted February 12, 2012 Share Posted February 12, 2012 Cool car Link to comment Share on other sites More sharing options...
Graham1984 Posted February 12, 2012 Share Posted February 12, 2012 Cool car I suppose my NA is quite cool.... Thanks Gaz Link to comment Share on other sites More sharing options...
a98pmalcolm Posted February 12, 2012 Author Share Posted February 12, 2012 Its Plug and Play But some wiring for Traction control is needed to be done from ABS ecu. Instructions comes with it though Ryan Thanks for the work Ryan Link to comment Share on other sites More sharing options...
jjs_82 Posted February 12, 2012 Share Posted February 12, 2012 What way dose the traction control work now. Ryan when you say its sounds amazing what dose it sound like. Is it like anti lag or something. Link to comment Share on other sites More sharing options...
Gaz6002 Posted February 12, 2012 Share Posted February 12, 2012 I suppose my NA is quite cool.... Thanks Gaz Yep, it's freezing at the moment isn't it? You should get a heated garage Link to comment Share on other sites More sharing options...
Graham1984 Posted February 12, 2012 Share Posted February 12, 2012 Yep, it's freezing at the moment isn't it? You should get a heated garage Well played Link to comment Share on other sites More sharing options...
