Josh42 Posted February 10, 2012 Share Posted February 10, 2012 (edited) Thinking of NA-T Not going to be a fast build though, want to do it right, so will be at least a year. Going to buy another 2JZ-GE block, and build it before dropping it in. Below are a list of items I think I'll need, can anyone think of anything else? NA engine TT pistons TT head gasket TT Auto box TT injectors T4 turbo SSQV FMIC Mines ECU 3" Exhaust Double Decat TT inlet Manifold(?) Boost Controller FCD Walbro fuel pump Edited February 10, 2012 by Josh42 (see edit history) Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted February 10, 2012 Share Posted February 10, 2012 fuel pump injectors Quote Link to comment Share on other sites More sharing options...
heckler Posted February 10, 2012 Share Posted February 10, 2012 Exhaust maifold... Standalone ECU. - this can also replace the FCD and boost controller Wastegate Larger Injectors Uprated Fuel Pump All I can think of at the moment... Quote Link to comment Share on other sites More sharing options...
Josh42 Posted February 10, 2012 Author Share Posted February 10, 2012 Would the Mines not do all that=)? Quote Link to comment Share on other sites More sharing options...
heckler Posted February 10, 2012 Share Posted February 10, 2012 Would the Mines not do all that=)? depends what its off - NA - no, TT no... you will still need a piggyback ECU at least to control it all. If you ask me, a piggyback is just not worth the hasstle. Stock N/A ECU not designed to deal with Boost, TT ECU is designed to work with twin stock turbos.. Quote Link to comment Share on other sites More sharing options...
Josh42 Posted February 10, 2012 Author Share Posted February 10, 2012 What would you reccommend? Syvecs? Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted February 10, 2012 Share Posted February 10, 2012 (edited) Would the Mines not do all that=)? you want the best standalone ecu on the market, its the heart of the build and then get the best mad scientist to map it- points to Ryan G Syvecs!! Edited February 10, 2012 by Rob_Mitchell (see edit history) Quote Link to comment Share on other sites More sharing options...
heckler Posted February 10, 2012 Share Posted February 10, 2012 What would you reccommend? Syvecs? Yup, or an AEM - but would also need a HKS DLI for an AEM Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted February 10, 2012 Share Posted February 10, 2012 I did a thread on this a while ago ill try and find it. Quote Link to comment Share on other sites More sharing options...
Josh42 Posted February 10, 2012 Author Share Posted February 10, 2012 Cheers=] All I'm thinking is that if I make it a long term project, for one I'll be older, for two it doesn't require a massive capital in one lump sum, and this way I can build it exactly how I want it. What do you guys think? Quote Link to comment Share on other sites More sharing options...
heckler Posted February 10, 2012 Share Posted February 10, 2012 Cheers=] All I'm thinking is that if I make it a long term project, for one I'll be older, for two it doesn't require a massive capital in one lump sum, and this way I can build it exactly how I want it. What do you guys think? I did mine bit by bit... just plan on how your going to attack it! Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted February 10, 2012 Share Posted February 10, 2012 Cheers=] All I'm thinking is that if I make it a long term project, for one I'll be older, for two it doesn't require a massive capital in one lump sum, and this way I can build it exactly how I want it. What do you guys think? Good idea, Try and buy the Very best bits for the build as you can and dont turn you nose up at second hand parts in the forsale section. I would go for the garage whifbits turbo kit if i went this route, such save the pennys Quote Link to comment Share on other sites More sharing options...
mellonman Posted February 10, 2012 Share Posted February 10, 2012 i think alot of think alot of people forget about are oil lines water lines breather system turbo blanket also do not go aem fic trust me they work but they are rubish AEM ( Afordable Engine Management) and you get what you pay for Quote Link to comment Share on other sites More sharing options...
heckler Posted February 10, 2012 Share Posted February 10, 2012 i think alot of think alot of people forget about are also do not go aem fic trust me they work but they are rubish AEM ( Afordable Engine Management) and you get what you pay for is that just for the FIC? as I had the standalone AEM ECU - that worked fine for me.. Quote Link to comment Share on other sites More sharing options...
JamieP Posted February 10, 2012 Share Posted February 10, 2012 Yup, or an AEM - but would also need a HKS DLI for an AEM Id steer clear of AEM standalone on a auto car, syvecs or motec imo. You only need a dli with the old series 1 AEM's, later ones dont need one. Quote Link to comment Share on other sites More sharing options...
Josh42 Posted February 10, 2012 Author Share Posted February 10, 2012 That's the other part of the plan with having a separate engine, so I can take my time and do it with top quality bits, not necessarily new, but without losing the car as its my daily driver=] Quote Link to comment Share on other sites More sharing options...
mellonman Posted February 10, 2012 Share Posted February 10, 2012 i hear the stand alone is good but not had any dealing with it but i have had the fic and the afr and yes they work but not great fic , works but is just not great as it dont like magnetic cam and crank signals which cause miss fires afr, it can not simulate a narrow band signal that my supra likes it dont even out put a voltage when set to simulate p4 on dial after research on the aem forum i see 100s of people ripping the stuff out if i knew then what i knew now i would never touch aem. just my opinion as i have had bad experiances. i would check out the forum before buying anything though to see what problems they have, goes for every company Quote Link to comment Share on other sites More sharing options...
TheTurtleshead Posted February 10, 2012 Share Posted February 10, 2012 I have an N/A engine you can buy if you want? 60k miles. Quote Link to comment Share on other sites More sharing options...
Ricky49 Posted February 10, 2012 Share Posted February 10, 2012 Get your cheque book out, phone the credit card company and pre warn them of the raping its going to get. Say hello to debt. Speak with SRD, a never ending pit of info over there. Quote Link to comment Share on other sites More sharing options...
dude Posted February 10, 2012 Share Posted February 10, 2012 Yup, or an AEM - but would also need a HKS DLI for an AEM 1st choice would be Syvecs, 2nd F Con Pro dont like AEM at all, seen too many fail, I have an f-con on my road car and race car will be syvecs S8 (Ryan tapping the keys on the race car !!!) Quote Link to comment Share on other sites More sharing options...
