Fuel pump ECU
BABZ988
It's the other way round, the fuel pump ecu needs feedback FROM the engine ecu. In 99% of setups there's no reason to fiddle with this at all. It keeps the fuel cooler and wears the pump less if left to work as intended.
Say I a walbro, say maybe even two of them, will the stock fuel pump ecu switching voltage still be ok or should it be whipped out?
A single pump is fine, but if the set up needs two pumps it's obviously quite radical and you should either bypass it, or find a controller that will handle more current. I'd try and avoid twin pumps unless there's no alternative, won't a Bosch 044 in the tank be enough?
One will be fine at first, will need the second one eventually though. I had thought putting the two in now would have been fine aslong as my return line could keep rail pressure down.
