Next logical step?
Guest cadmkiv
Guest cadmkiv
hey looking for imput,
currently BPU looking to progress to APU but want to do it in stages (2 years/2 stages).
1993 Jspec RZ 60,000 km 6 speed
current parts/ specs are:
Electric rad fan/shroud
aluminum rad
rad cooling plate
Blitz 4inch intercooler and piping
Blitz Access ECU
Blitz Boost gauge
HKS Super dragger 4'inch
HKS SSQV
single decat pipe
APEXi intake
RPS Max Series 6 Puck Sprung Hub Clutch
Fidanza Lightweight Aluminum Flywheel
TRD trans mount
Titan 264 intake/exhaust cams
Titan cam gears
unorthodox lightweight pullies
Gates cam belt
Gates aux belt
new oem water pump
new oem oil pump
NKG spark plugs
so currently there is little i can do to push my BPU any further so im wanting to go single soon i just don't know what is best to start with. i do plan on going with the Pro EFI from SP thus i have not spent money on all the other gauges because I will just get the CAN display and have every gauge i could need in one and also have the boost controler and every other possible function.
my question is does it make sense to get the proefi first and run it with stock fuel and turbo and then do turbo/ fueling the following year? does anyone every upgrade the computer and run stock components (knowing that this will be done for a short amount of time) or should i run stock turbo on upgraded fueling and computer (clearly at very low boost/ duty cycle).
Financially i can not do all at once.. but over time i would expect to get all three but what make logical sense to upgrade and in what order? or is there anything you would add first.
lol, Never heard of that one, thanks both of you, learn something every day
As you can see MrRee I am as much use to your thread as plastic brake pads. So I will wish you good luck and leave :)
It's an American-ism... much like BPU is. We don't use the term over here hence why you haven't heard of it before. It isn't MrRee's thread either, he was just helping you out as I was. Now sit down and pay attention :p
C- Could try harder.
Guest cadmkiv
also i guess another good question would be for all the other Jspec guys out there with the smaller brakes, what BBK have you gotten? what are you upgrading to.
You'll probably be around 400hp with stock turbos and aftermarket cams at 1.2bar. The stock 440cc injectors will be at the limit at that power, if you fitted bigger injectors and mapped ECU it'd be possible to get around 430hp max.
The most popular brake upgrade is to fit the larger front 4pot/rear 2pot Supra brakes, they are big improvement over the smaller brakes.
Agreed, the 4/2 pots with a suitable brake pad compound to match the type of use your car gets.
BBK's are typically installed by people for aethetic reasons, as very few people push their A80 hard enough to need more braking than the 4/2 offers.
Just be sure to buy quality rotors to go with the new callipers/pads, as the metal they are made from has a huge bearing on their abiltiy to cope with prolonged heat. The cheap aftermarket rotors will not be worth the money you save over the oem items
