skippyboyo1 Posted June 14, 2012 Share Posted June 14, 2012 You have too mate due to the way the shine auto diffuser mounts I'm confused lol, so there's no way to get the diffuser on without taking the spats off? Even though the spats are staying on and no carbon end plates will be fitted? Quote Link to comment Share on other sites More sharing options...
ripped_fear Posted June 14, 2012 Share Posted June 14, 2012 I'm confused lol, so there's no way to get the diffuser on without taking the spats off? Even though the spats are staying on and no carbon end plates will be fitted? The fittings that you use to mount the diffuser bolt on via the same wholes you use to mount the spats, You can mod the brackets to stop this like dodgy rog did for his wide body. The carbon end plates you are referring to i assume you mean the vortex generators, these bolt to the edge of the shine diffuser. Quote Link to comment Share on other sites More sharing options...
skippyboyo1 Posted June 14, 2012 Share Posted June 14, 2012 The fittings that you use to mount the diffuser bolt on via the same wholes you use to mount the spats, You can mod the brackets to stop this like dodgy rog did for his wide body. The carbon end plates you are referring to i assume you mean the vortex generators, these bolt to the edge of the shine diffuser. Ohhhhh so the diffuser bolts to the rear arch then you put your spat over this I'm guessing hence having to take the spat off? I've read that with spats the vortex generators won't fit? Quote Link to comment Share on other sites More sharing options...
ripped_fear Posted June 14, 2012 Share Posted June 14, 2012 Ohhhhh so the diffuser bolts to the rear arch then you put your spat over this I'm guessing hence having to take the spat off? I've read that with spats the vortex generators won't fit? Now you got it! Thats correct. Quote Link to comment Share on other sites More sharing options...
skippyboyo1 Posted June 14, 2012 Share Posted June 14, 2012 Now you got it! Thats correct. Mate thanks alot for your time I now understand.......commence ripping spats off!!! Quote Link to comment Share on other sites More sharing options...
ripped_fear Posted June 14, 2012 Share Posted June 14, 2012 Mate thanks alot for your time I now understand.......commence ripping spats off!!! No worries mate, if i get mine fixed i will be getting mine asap so i need to rip mine off too, but they are staying off. Quote Link to comment Share on other sites More sharing options...
DuaneT.Turbo Posted June 15, 2012 Author Share Posted June 15, 2012 No worries mate, if i get mine fixed i will be getting mine asap so i need to rip mine off too, but they are staying off. All sorted, as "ripped_fear" said, the vortex generators fix the the diffuser and use the same holes as the spats... in a fasion, you may want to mark out to them holes before drilling the carbon. The brackets that hold the front up needed modding because they didnt fit, they were too long so had to modify the slots and shorten, there is only 1 location for the back centre to drill on the diffuser but you will definatly need at least 3 equally spaced to get it to hang right. I wont be going to Japshow with this inconsistent weather but should be at Japfet 2 at Donnington if you need ayn more help D Quote Link to comment Share on other sites More sharing options...
DuaneT.Turbo Posted August 17, 2012 Author Share Posted August 17, 2012 Not a bad days work done today, made template, cut wings, filed flat and rounded corners, painted black behind vents and painted edges white, and moved side repeaters! Just need to put mesh on when it arrives. The picture is the right way round on photobucket so dont know why its rotated on here..... sorry.. Quote Link to comment Share on other sites More sharing options...
ripped_fear Posted August 17, 2012 Share Posted August 17, 2012 Looks good mate. You changing the wheels in the future? Quote Link to comment Share on other sites More sharing options...
DuaneT.Turbo Posted August 20, 2012 Author Share Posted August 20, 2012 I didnt have plans too, just a good refurb is the second step, next step is to cut bonnet like wings. Quote Link to comment Share on other sites More sharing options...
DuaneT.Turbo Posted September 17, 2012 Author Share Posted September 17, 2012 So i've cut my bonnet, bonded the mesh to the underside, what are peoples thoughts on rain trays? Do they have to cover the length of the bonnet or do people cover the holes and stop at that? Cheers D Quote Link to comment Share on other sites More sharing options...
welshbuddy Posted September 17, 2012 Share Posted September 17, 2012 photos Quote Link to comment Share on other sites More sharing options...
DaveR Posted September 17, 2012 Share Posted September 17, 2012 Love your car matey. Very And yes, it looks LOADS better without the shopping list! Quote Link to comment Share on other sites More sharing options...
DuaneT.Turbo Posted September 18, 2012 Author Share Posted September 18, 2012 I'll get pics when the bonnets back on the car Quote Link to comment Share on other sites More sharing options...
ashbuster Posted September 18, 2012 Share Posted September 18, 2012 i have to try and come up with something for my bonnet too so the rain runs down instead of all over my engine. Quote Link to comment Share on other sites More sharing options...
scott87 Posted September 18, 2012 Share Posted September 18, 2012 i have to try and come up with something for my bonnet too so the rain runs down instead of all over my engine. I also need to do this with my car! Still trying to figure it out. Let me know if you have a light bulb moment. Quote Link to comment Share on other sites More sharing options...
ashbuster Posted September 18, 2012 Share Posted September 18, 2012 i think i will end up making some sort of shallow tunnel running down the centre of the bonnet with carbon fibre and bonding it on with the resin. Quote Link to comment Share on other sites More sharing options...
DuaneT.Turbo Posted September 18, 2012 Author Share Posted September 18, 2012 Im going to make a tray under the vents with sides on all sides apart from the from so water has to go that way. Then either try and use the original black clips or self tap it to the supports. Quote Link to comment Share on other sites More sharing options...
DuaneT.Turbo Posted October 7, 2012 Author Share Posted October 7, 2012 So I put the car back together now, car needs a good clean now but heres a preview pic Quote Link to comment Share on other sites More sharing options...
DuaneT.Turbo Posted October 10, 2012 Author Share Posted October 10, 2012 Heres a pic as it stands now bonnet and wings cut not too bad Quote Link to comment Share on other sites More sharing options...
ashbuster Posted October 10, 2012 Share Posted October 10, 2012 that looks nice mate, not sure about the front because cant see it properly but looks nice and clean is the front a trial? Quote Link to comment Share on other sites More sharing options...
DuaneT.Turbo Posted October 11, 2012 Author Share Posted October 11, 2012 Not sure what the front is to be honest, slight differences to the ones i've seen.. Quote Link to comment Share on other sites More sharing options...
ripped_fear Posted October 11, 2012 Share Posted October 11, 2012 Its a border front bumper- http://carphotos.cardomain.com/ride_images/2/3526/1641/21313320005_large.jpg Quote Link to comment Share on other sites More sharing options...
DuaneT.Turbo Posted October 11, 2012 Author Share Posted October 11, 2012 Ta very much Quote Link to comment Share on other sites More sharing options...
scott87 Posted October 11, 2012 Share Posted October 11, 2012 Border front, had one on my mr2. What did you do to catch rain under the vents in the end? Quote Link to comment Share on other sites More sharing options...
