Radiator and associated gubbings
mattdavies
I am in need of a new Radiator, fan and shroud. I was wondering what on the supra across the models is universal and what is specific. What are the different shrounds that there are and what will they and wont they work with fan wise ?
Also when purchasing these items is there anything to avoid ? and what about aftermarket fans could i just bolt one to any supra radiator shroud ?
Thanks
Fan and coupling is model specific, shrouds are different between the 2 models but will fit all the same. The TT's utilise a smaller fan so if you have a TT then you need a TT specific shroud.
Avoid cheap electric fans. OEM is superior IMO and I've give you my opinion on the radiators. A reply wouldn't go a miss ;)
Ok then i have the smaller fan so can always modify the N/a shroud to accept it. The only issue with my radiator is im an auto so have a trans cooler in it ( basically an extra two hose on the bottom )
So OEM is the best but where would be the best place to get a complete fan ? and how would i know if it is goin to fit ?
