skyludeboy Posted February 6, 2012 Share Posted February 6, 2012 Cut a long storey short, I was driving along a dual carriage way approx 50-60ish all of a sudden I get no throttle response with car still running and revs just coming down as I slow down I managed to wheel the car to a slip road, the car cuts off and will not start I started to investigate roadside, and have established I have no spark, I have checked all fueses they seem ok, the car is getting fuel, but I cannot figure out how it can loose spark while driving all fine, now that there is no spark to fire up, I am thinking that say if that the trigger wheel came away from the lower cam belt sprocket will this give me no spark too? I am baffled as I dont know where to start to solve the sparking issue, any one have faced similar experiences. The engine has been fully rebuilt uprated internals, been driving around for 2 weeks, due to be mapped this thursday, current fuel management is hks f con v pro and 850cc injectors and t51r. help appreciated thanks. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted February 7, 2012 Share Posted February 7, 2012 Try a new ignitor perhaps? Quote Link to comment Share on other sites More sharing options...
Lude Posted February 7, 2012 Share Posted February 7, 2012 any connectors come undone? Quote Link to comment Share on other sites More sharing options...
fastcar Posted February 7, 2012 Share Posted February 7, 2012 i would say the ignitor. I had the same problem with mine back a few years ago. Maybe try and borrow an ignitor of someone and see if it starts up if it does then problem solved Quote Link to comment Share on other sites More sharing options...
skyludeboy Posted February 7, 2012 Author Share Posted February 7, 2012 found the problem took the timing tensioner off and crank angle sensor, and found the trigger wheel loose which had come off the sprocket, gonna open it all up again Quote Link to comment Share on other sites More sharing options...
