carlmhtt Posted February 7, 2012 Share Posted February 7, 2012 Thats nots so bad then, Ill whip the pulley back off and remove the cover easy enough. I just dont want to remove the belt as it was a bit fussy to get set up spot on the marks. Link to comment Share on other sites More sharing options...
carlmhtt Posted February 8, 2012 Share Posted February 8, 2012 Just an update to ths post, no you can't get the water pump off without removing the cambelt. Reason being there is a bolt behind the top cover so it can only be accessed by removing cam pulleys and top cover. There is also a bolt behind the cambelt tensioner wheel so that has to come off to. In short there is no short cut to get it off as I found out. I guess I'll be getting pretty good at setting up the cambelt though..lol Link to comment Share on other sites More sharing options...
carlmhtt Posted February 13, 2012 Share Posted February 13, 2012 IMG_0139.JPG I have just ordered a new gasket and was about to fit the water pump to my TT except it won't fit. As you can see from the new gasket three of the bolts don't line up. Also the wheel itself is steel on this where as the one I took of is a plastic type wheel. Needless to say after dismantling everything for nothing I'm a little annoyed. I'm not sure how others on here say they fitted a TT to a na when it seems clear the two are not compatible unless I'm missing something. New na pump: IMG_0136.JPG by Mr_CH_lense, on Flickr Old jspec TT pump: IMG_0137.JPG by Mr_CH_lense, on Flickr Link to comment Share on other sites More sharing options...
