Removing oem skirts and spats
Supra Gaz
I have used the ever useful search button I i can't see what im after. I am looking to remove my oem spats and skirts, the spats look like they have been taken off at some point and put back on, as one side has some sort of horrible putty stuff around it. My question is, what is underneath the skirts and spats? if i take off the skirts i know i need the rear vent bit but what else will i need? it I have found out how to take off the skirts but not the spats also. ny pictures would be great, best answer will win some haribos! Tangtastic i think.
I would think VERY careful use of a heat gun would be my starting point. Possibly fitted with 'tiger seal' which a search on the net may help with advice. the spats have 1 fixing underneath and 3 or 4 on the arch, they are usually fitted with double sided auto tape around the edge
afterwards you will need some trim to replace some parts along the sill and at the rear of the front arch and the front of the rear, if you get me :)
Forget the haribo just send me your skirts :)
R.
