Euro EPC Request - UK Dash Panels
Nic
I'm not sure which panels on the UK spec Supra are the same/different to the J-spec, I think it is just the ignition panel. Could someone post images and part numbers of the UK spec dash panels for me please, including gear surround and drivers door window switch panel. :thanks:
Sorry Nic, jumping on your thread a bit here, but I'm also looking for a part number from the dash area for the headlamp adjustment thumbwheel as stated in this post: http://www.mkivsupra.net/vbb/showthread.php?t=43533
If someone is already looking at the dash panels for you then my info is most likely at hand also.
Heh, someone like yourself should definitely "invest" in an EPC ;)
I've got the Jap EPC set up, it is just the UK ones I can't get ATM. I have the files for the Euro EPC but need to burn them onto disc first, but don't have a disc burner :(
