Clifford Windscreen LED
Suprab1
I just noticed lastnight that the LED windscreen flasher thingy has went all patchy (only flasing in patchys), i thought this would have been 1 led that just lit the clifford logo but if so how could it go patchy?
Anyone else seen this happing or cured it?
Huh?
Think OP is referring to this:
If it is that then it isn't an LED, it is the same sort of technology as like the Plasma Dials or El Glow.
You can buy replacements from eBay for about £15. I have one in my car :)
I'm still none the wiser. I understand that it's clifford, and it does something with the windscreen.... and the op is having an issue as the thing it should be doing it isn't doing correctly.
I guess I won't be of any help anyway :D
You got it now! :D
OP - If you can find where the wire is connected to then double check the connection. Take it your battery is good? Even though these draw little current. If it is patchy as you mentioned then I'd say something has possibly gone wrong with the unit itself. Scott has linked the replacement you need.
