Scott Posted February 5, 2012 Share Posted February 5, 2012 I spent an hour or so on the harness today and really want to get it finished so that I can start to get things back together. I think I have sussed out just about everything I need (and labelled them accordingly) but I can't remember where this one came from.... Next is my throttle body. I've got another one coming from Stuart that has the TC bypassed and welded up. Am I right in saying that both of the marked components are now null and void and also the connections going to them? Lastly I'm looking at the manifold itself. I know of the MAP sensor but what is the other sensor that is there? Is that for intake temperature? Also what about the little outlet with what appears to be a filter on it.... is it a filter? Is that for the stock BOV or something? Any help and info would be greatly appreciated Link to comment Share on other sites More sharing options...
D8MOA Posted February 5, 2012 Share Posted February 5, 2012 1st pic appears to be the starter motor trigger wire Link to comment Share on other sites More sharing options...
hodge Posted February 5, 2012 Share Posted February 5, 2012 Ok Scotty, Pic 1, I think goes to the starter motor but the pic is a little unclear. Pic 2, yes your correct those 2 are not needed as the Syvecs has its own trac control. Pic 3, 1 is the map sensor which you can put in the bin cos the Syvecs uses a different one. The other is the intake temp sensor. The small round vac pipe is a 1 way valve which can be removed and another normal vac fitting can be used for any vac reference you will need. BOOOOOOOM there you go Link to comment Share on other sites More sharing options...
Scott Posted February 5, 2012 Author Share Posted February 5, 2012 Thats great, thanks guys. It will be the starter trigger, totally forgot about it and it's not accounted for. Do I need the upgraded MAP sensor John? I didn't buy one, wondering if I should have now lol. Cheers Link to comment Share on other sites More sharing options...
hodge Posted February 5, 2012 Share Posted February 5, 2012 Thats great, thanks guys. It will be the starter trigger, totally forgot about it and it's not accounted for. Do I need the upgraded MAP sensor John? I didn't buy one, wondering if I should have now lol. Cheers Yes mate. IIRC the Syvecs uses a 3 bar map sensor. Ryan supply's these. There not expensive. Link to comment Share on other sites More sharing options...
