Jezz Posted July 27, 2005 Share Posted July 27, 2005 Flashing amber slip cont off, flashing o/d off. Any ideas anyone? My overdrive works fine and light stays on when o/d off, switch it on and the light flashes?! As for the slip control, it dont do anything other than flash like a pervert. Green light doesnt come on at all. Checked bulbs and they're all fine. Link to comment Share on other sites More sharing options...
Jake Posted July 27, 2005 Share Posted July 27, 2005 Possibly a faulty earth on the DSC. while you're at it, check the connection on all four dsc wires Link to comment Share on other sites More sharing options...
Nic Posted July 27, 2005 Share Posted July 27, 2005 If you pull the trac fuse (or it has blown), the "slip control off" light flashes orange. Many members pull the trac fuse to permanently disable the stock traction control, as it is completely cr*p. Took my trac fuse out shortly after I bought the car, around 7 years ago, eventually removed the bulb for the orange warning light this year, when I had the dash apart. The fuse is located in the fuse box in the engine bay, the inside of the fuse box cover will show you which it is. Link to comment Share on other sites More sharing options...
heckler Posted July 28, 2005 Share Posted July 28, 2005 mine intermittently flashed when the trac ecu died... the ecu is now a door stop ;p Link to comment Share on other sites More sharing options...
Jezz Posted July 28, 2005 Author Share Posted July 28, 2005 I can hear a race logic unit calling me...........'buy me, buy me'..... Link to comment Share on other sites More sharing options...
