2jz differances
Guest 2jz200
Hi everyone im new to the forum just a quick queestion,
Is the 2jz from the Aristo 2jz (jzs147) and the supra 2jz (jza80) the exact same engine ie, are engine parts turbo injectors ect ect interchangable on the two engines?
if i bought uprated supra injectors or ecu or anything like that could i fit to the aristo engine, the reason i ask is because im soon gonna be fitting a 2jz into my 200sx an before i choose an engine just wanted to know this first?
Thanks Paul
Are the sumps changeable I know you need the forward facing sump off of the Aristo, also what other major differances are there between the 2? 2jz swap has been done quite a few times n fit quite nicely
there are a few people on here who have aristo 2JZ powered Supras,
there are a few differences as previously posted, if you look at hodge on here, i think his is an aristo engine.
think looms and ECU differ slightly too
