Noz Posted February 4, 2012 Share Posted February 4, 2012 (edited) Out of internet, the NA motor uses 7mgte injectors (I have some 440's in mine), does this mean it would be easy enough to use a 7mgte uprated fuel rail? EDIT: The injector to injector distance I spose would have to be measured. Found the answer to my question. For reference, this can't be done. I only wondering it as you can swap injectors. Worth a try!: http://www.supraforums.com/forum/showthread.php?627116-Will-a-2jzGE-fuel-rail-fit-the-1JZ Edited February 4, 2012 by Noz (see edit history) Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted February 4, 2012 Share Posted February 4, 2012 No, the injector bore spacing is almost certainly different for a start. Quote Link to comment Share on other sites More sharing options...
Noz Posted February 4, 2012 Author Share Posted February 4, 2012 I would assume it would of been covered anyway, but I thought it was worth asking. Thanks Quote Link to comment Share on other sites More sharing options...
Mr Ree Posted February 5, 2012 Share Posted February 5, 2012 The GE fuel rail is more than adequate for the typical na-t set up so I wouldnt worry too much about upgrading. Quote Link to comment Share on other sites More sharing options...
Noz Posted February 5, 2012 Author Share Posted February 5, 2012 Me Ree! Nice to see you on here mate I'm jayforever21 on clubna-t. Glad to see you have finally joined this forum! Hows the motor coming along. Quote Link to comment Share on other sites More sharing options...
David P Posted February 5, 2012 Share Posted February 5, 2012 I had a set of N/A high impedance injectors ultrasonically cleaned and rebuilt to 550cc for mine, it cost about £20 each. Quote Link to comment Share on other sites More sharing options...
Noz Posted February 5, 2012 Author Share Posted February 5, 2012 Were they the stock 330's mate? Quote Link to comment Share on other sites More sharing options...
David P Posted February 5, 2012 Share Posted February 5, 2012 Yes. Quote Link to comment Share on other sites More sharing options...
