carnt do the 1st decat
ashbuster
It shouldn't be expensive if everything goes smoothly.... however, the studs are prone to shearing off (they did on mine) which meant the elbow had to come off for them to be drilled out & then a had to source some studs. Luckily Chris Wilson had some in stock and i was able to drive and pick them up :)
If you do manage to get somewhere to do it yourself i recomend getting some plusgas to release the bolts, and if you can get access to a compressor with air tools it will make the job so much easier. When i done mine a few of the studs come out when i was removing the bolts and they are very hard to get hold of as they have a different pitch to normal studs so i would recomend buying some before you start the job just incase.
