carlmhtt Posted February 4, 2012 Share Posted February 4, 2012 Has anyone used oil additives like STP STOP LEAK, which apparently swells just the seals and can prevent further small leaks. I'm always a bit dubious about such fixes? Carl Quote Link to comment Share on other sites More sharing options...
Lude Posted February 4, 2012 Share Posted February 4, 2012 for the rad u mean? Quote Link to comment Share on other sites More sharing options...
tony tt Posted February 4, 2012 Share Posted February 4, 2012 For a temp fix it may work but in the long term i would replace the problem. Quote Link to comment Share on other sites More sharing options...
Lude Posted February 4, 2012 Share Posted February 4, 2012 where is the leak from? if its the rad, i would just get a new rad. if its from a hose, i would just replace the hose.... Quote Link to comment Share on other sites More sharing options...
carlmhtt Posted February 4, 2012 Author Share Posted February 4, 2012 where is the leak from? if its the rad, i would just get a new rad. if its from a hose, i would just replace the hose.... It's from the rear engine seal (crank seal) and just a few drops. It's on my Lexus is ,not my supra. To replace seal would cost £60 for new seal plus £ 240 to fit it as it involves dropping test box etc. Quote Link to comment Share on other sites More sharing options...
SteveC Posted February 4, 2012 Share Posted February 4, 2012 Has anyone used oil additives like STP STOP LEAK, which apparently swells just the seals and can prevent further small leaks. I'm always a bit dubious about such fixes? Carl If it's a relatively minor leak where there's a drop of oil every few hours, then one of these seal fixes may have a chance. Going off my experience many years back, when you've a fairly noticeable leak these products do little to no good. The money would probably be much better spent by putting it towards a proper cure. ...and don't forget, if it does actually swell seals, then it's swelling all the seals in the engine including those that weren't causing any problems. I don't think that can be a good thing in the long term. Quote Link to comment Share on other sites More sharing options...
Attero Posted February 4, 2012 Share Posted February 4, 2012 When I was 17 and knew nothing about cars, I filled my 106 up with the stuff thinking it was oil. Unfortunately I didn't have any leaks to give you any conclusions. Only that it doesn't work as a replacement for oil. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted February 4, 2012 Share Posted February 4, 2012 What engine is in the Lexus, if it's a 2JZ i have a job lot of seals, including rear crank seals i am selling 1/3 price. No way would I put something that alters seal texture in the engine oil. Either fix it or live with it would be my advice. Quote Link to comment Share on other sites More sharing options...
carlmhtt Posted February 5, 2012 Author Share Posted February 5, 2012 What engine is in the Lexus, if it's a 2JZ i have a job lot of seals, including rear crank seals i am selling 1/3 price. No way would I put something that alters seal texture in the engine oil. Either fix it or live with it would be my advice. It's a 2006 220 diesel Chris. Perhaps you coud email me a price for the seal. don't suppose you get discount for the clutch kit as well do you as they cost about £500 from main dealer? carl Quote Link to comment Share on other sites More sharing options...
D8MOA Posted February 5, 2012 Share Posted February 5, 2012 It's a 2006 220 diesel Chris. Perhaps you coud email me a price for the seal. don't suppose you get discount for the clutch kit as well do you as they cost about £500 from main dealer? carl sure its not another seal? haven't seen meny 1AD/2AD engines with rear main seal's leaking? ( not to say its not obv) Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted February 5, 2012 Share Posted February 5, 2012 It's only seals for the 2JZ series I have, sorry. £500 isn't dear for a diesel clutch, it sounds quite reasonable. Quote Link to comment Share on other sites More sharing options...
carlmhtt Posted February 5, 2012 Author Share Posted February 5, 2012 sure its not another seal? haven't seen meny 1AD/2AD engines with rear main seal's leaking? ( not to say its not obv) That's what Lexus told me at the last full service... Quote Link to comment Share on other sites More sharing options...
