drift_bear Posted February 3, 2012 Share Posted February 3, 2012 I was thinking about this a few days ago while on my lunch break at work, how easy would it be to drop a supra TT lump into a lexus is200 and have it running BPU? The cost? Who would do it? Link to comment Share on other sites More sharing options...
SamuraiFlash Posted February 3, 2012 Share Posted February 3, 2012 I am also very interested in this swap as I will need a family car with my son growing up. Another car that I would like to swap a 2JZ into is the RX8. Link to comment Share on other sites More sharing options...
dude Posted February 3, 2012 Share Posted February 3, 2012 IS easy as you are making a IS300 RX a kit is available Link to comment Share on other sites More sharing options...
drift_bear Posted February 3, 2012 Author Share Posted February 3, 2012 IS easy as you are making a IS300 RX a kit is available Is that for a 2JZ into an IS200 dude? I wouldn't mind having another lexus as it was a good car and great fun to drive, just lacked decent power level compared to the supe Link to comment Share on other sites More sharing options...
dude Posted February 3, 2012 Share Posted February 3, 2012 Is that for a 2JZ into an IS200 dude? I wouldn't mind having another lexus as it was a good car and great fun to drive, just lacked decent power level compared to the supe /QUOTE] Lexus IS 300 has a 2JZ motor but NA I would presume the sump etc are from a GS300 but it will all just bolt in, IS300's are all auto (IS200 and 300 are same shell BTW) Link to comment Share on other sites More sharing options...
Guest ugp Posted February 3, 2012 Share Posted February 3, 2012 As Dude said, Aristo TT motor will drop in, I've wired one up, quite easy to do, although custom prop is required if going manual. Link to comment Share on other sites More sharing options...
drift_bear Posted February 3, 2012 Author Share Posted February 3, 2012 As Dude said, Aristo TT motor will drop in, I've wired one up, quite easy to do, although custom prop is required if going manual. Any idea how much It would cost to do the conversion and would the 6 speed lexus box be able to work? I just want to find out as much as I can! Link to comment Share on other sites More sharing options...
dude Posted February 3, 2012 Share Posted February 3, 2012 Any idea how much It would cost to do the conversion and would the 6 speed lexus box be able to work? I just want to find out as much as I can! Lexus box will last about a day, the 2ltr screws em !!!! a 154 is cheapest option. Link to comment Share on other sites More sharing options...
drift_bear Posted February 3, 2012 Author Share Posted February 3, 2012 If the NA would drop straight in, then how can't a TT? Is the W154 not weaker than the lexus 6 speed box? I'm just wanting to find out all the info I would need if I wanted to go down this route and find somewhere that would take on the challenge with a rough price. Link to comment Share on other sites More sharing options...
SamuraiFlash Posted February 4, 2012 Share Posted February 4, 2012 Dude will an aristo TT engine and autobox just fit straight into an is300? Link to comment Share on other sites More sharing options...
dude Posted February 4, 2012 Share Posted February 4, 2012 I believe it will, all parts are available from a smashed IS300 jus wiring to sort if you want a TT Link to comment Share on other sites More sharing options...
j_jza80 Posted February 4, 2012 Share Posted February 4, 2012 If the NA would drop straight in, then how can't a TT? Is the W154 not weaker than the lexus 6 speed box? I'm just wanting to find out all the info I would need if I wanted to go down this route and find somewhere that would take on the challenge with a rough price. The Lexus manual box is the same as the S15 Silvia IIRC, which means its useless for tuning. Link to comment Share on other sites More sharing options...
SamuraiFlash Posted February 4, 2012 Share Posted February 4, 2012 I believe it will, all parts are available from a smashed IS300 jus wiring to sort if you want a TT Will it require more work to install the tt engine and autobox out of my supra into an is200/300? Link to comment Share on other sites More sharing options...
dude Posted February 4, 2012 Share Posted February 4, 2012 Will it require more work to install the tt engine and autobox out of my supra into an is200/300? You need the sumps and maybe mounts from a GS300/IS300 the box and prob may well slot straight in but some wiring to get the ecu in. Link to comment Share on other sites More sharing options...
SamuraiFlash Posted February 4, 2012 Share Posted February 4, 2012 You need the sumps and maybe mounts from a GS300/IS300 the box and prob may well slot straight in but some wiring to get the ecu in. Thanks dude! Cab you pm me a price if i was to provide you with an is300 and the tt engine and box. will the drive shaft, diff etc on an is300 be ok with the extra power from a 2jz gte engine? Link to comment Share on other sites More sharing options...
garethr Posted February 4, 2012 Share Posted February 4, 2012 There is a lot of info on my.is, although the Americans are more likely to start with an IS300 (and they have a manual version). Actually, I'm not sure if the IS200 was ever sold over there. Link to comment Share on other sites More sharing options...
dude Posted February 4, 2012 Share Posted February 4, 2012 From memory the diffs etc are all the same or similar to a Supra, Ill do some research. Remind me tomorrow in work time. Link to comment Share on other sites More sharing options...
SamuraiFlash Posted February 4, 2012 Share Posted February 4, 2012 From memory the diffs etc are all the same or similar to a Supra, Ill do some research. Remind me tomorrow in work time. Will do, thanks Link to comment Share on other sites More sharing options...
drift_bear Posted February 4, 2012 Author Share Posted February 4, 2012 If i was to supply the IS200 and TT lump and w154 box where would do it and how much would i be looking at do you think? Link to comment Share on other sites More sharing options...
drift_bear Posted February 14, 2012 Author Share Posted February 14, 2012 hhhhmmmmmmm this has me thinking now http://www.turbofast.com.au/lexus.html Link to comment Share on other sites More sharing options...
